Solved Sound goes up with 4 instead of 2
axe0
BSOD Analyst & Security Analyst
Since a while I have a problem with my sound.
If I wanted to have my sound a little bit harder it used to go up with 2, but since the problem occured the sound goes up with 4.
I have a suspicion that the problem is with the program that shows the kind of images below.
Is there someone who knows a solution?
This is an annoying and big problem for me, because my ears are pretty sensitive.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
I checked my RealTek HD Audio Manager and there is nothing there to set how loud it gets.
If you are pressing a key on the keyboard to raise or lower the sound that is a function of the Dell control program.
Since this is a Dell, best to post on the Dell laptop forum where there are those familiar with the Dell applications.
http://en.community.dell.com/support-forums/laptop/
Nothing is changed and weird enough the problem is solved...
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
