Audio Services Not Running after Win8.1 update
    Recently I got update to my Windows 8.1 after which suddenly the audio services stopped working. I googled for solutions and found one as follows:
    1. Search for "services.msc" in start menu and open it.
    2. Go to "Windows Audio" service and open its properties by right clicking on it.
    3. Go to the "Log On" tab.
    4. Select "This Account" option and in that field type "NT AUTHORITY\LocalService".
    5. Restart the "Windows Audio" service.
    After performing these steps the speakers started to work but at very low volume.
    My system is hp-envy m6-1216tx which comes with beats audio speakers. I can't understand what the problem is. Maybe it has something to do with Beats Audio or with AVG antivirus (because I saw AVG being mentioned in many similar posts).
    Please Help!
    Trnava
    Win 8.1.1 Pro x64
    Try to reinstall your sound drivers.
    The newest I could find: Download IDT High Definition Audio Driver 6.10.6496.0 for Windows 8.1 64 bit
    Full size, but older version: IDT High-Definition (HD) Audio Driver | HP® Support
    @TairikuOkami Tried doing that. Did not help.
    Trnava
    Win 8.1.1 Pro x64
    Go to - Control Panel - Hardware and Sound - Sound - Right click on your soundcard - Properties
    Go to - Advanced - Uncheck - Allow applications to take exclusive control of this device - OK
    Go to - Communications - Select - Do nothing - OK
    Attached Thumbnails Attached Thumbnails capture_03232015_000723.jpg   capture_03232015_000732.jpg
    Thanks for your help, but even it did not help!
    I think maybe a system restore is required to solve the problem.
So i was running avg and it needed to restart my computer, when it started back up there is an X over the speaker in the bottom right hand corner. when hovered over it says "the audio service is not running" if I click it tries troubleshooting but just says that its not working. if I ask for...
All the sudden the other day every time I boot my laptop the audio service is not running, nothing loads in the notification area, and trying to open the network and sharing center/recovery/update/firefox results in a never ending load that I must terminate with the task manager. I have rebooted...
window audio in services in Sound & Audio
I found windows audio in services but cannot get it started it has a connection with window endpoint service in services which also will not start
Hi, I just installed a new program "Team Viewer 8". I disabled it from the startup and rebooted, but when I went to the task manager I see "TeamViewer_Service.exe" is running under SYSTEM. Can someone explain to me why it is running. I would prefer to stop a service when I close a...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
