A few days ago I had a windows update, and after it was done everything seemed fine. I muted my sound later on, and suddenly it wouldnt come back on. When I mouse over it, it says Audio Service is not running. After googling the problem I have done the following to try to fix it:
System recovery
Uninstall then Install AVG2015
Updated drivers
Disable then Enable the mmcss.dll file
Tried to start it via Run>Services>Windows Audio
Whenever I try to start it that way, I get Error 0x800706cc: the endpoint is a duplicate.
I really really dont know what else to do to fix it, and it's really getting to be upsetting. If anyone at all could help me out I'd be much appreciative.
System recovery
Updated drivers
- Windows 8.1
