The Audio Service is not running and can't restore
    Yesterday I turned on my computer and I was greeted without any sound. I think my computer updated when I went to bed the day before, so I thought that might've been the cause (or maybe it was AVG). So I looked up how to fix it and saw System Restore, tried that and was greeted with this:
    "System Restore failed to extract the file (C:/Windows/WinSxS/Manifests/AM37C0~1.MAN) from the restore point. The restore point was damaged or deleted during the restore."
    I don't know what to do now because when I tried to do the advanced recovery thing in PC Settings it won't load, and I can't make an ISO so I can do a refresh install. I'm very distressed, what do I do?
    Maybe your problem is bigger than just the audio and maybe you should post your issue in another area of the forum. Good luck.
    That's what I thought, but someone moved the thread here.
    Sadly most posts by users that have this problem wound having to do a Windows reinstall. There are many different fixes or suggestions on fixing it on the web but I've seen posts from users trying the various "fixes" and none worked. This is not to say that there is NO fix for the problem, just that most of the posts I've seen resulted in a reinstall to fix it.
    You could try, one at a time, removing the Updates to see if that fixes it. Go to the panel for Updates (easiest way is go to desktop and start Internet Explorer. In the Tools dropdown is the Windows Update. One option is to "View Update History" which lists installed updates and the date the update was installed. You can then go to Remove Programs and remove them, one at a time. It may be a time consuming process as you need to restart the PC after each update uninstall.
    I tried to go to View Update History but it ended up freezing, and when I tried to go to remove the updates it didn't load. I guess I'll have to do the reinstall, then?
    Sounds like more problems than just the audio service. It may take a reinstall.
    Would it be better for me to fully clean the drive or just remove my files?
    The best option when reinstalling is to do a complete "clean" install, which involved reformatting the hard drive. Thus, save all your user data, pictures, music, etc to some other media before doing the clean install as all will be lost.
    I did that and it worked! Thank you!
    Glad to hear it fixed it. But a big hassle.
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Hello, fellow... meh, I don't know. OS: Windows 8.1 Pro Processor: AMD FX-1400 Quad Core RAM: 8.00 GB Storage: 1.73 TB of 1.81 TB available System Type: 64-bit Operating System, x64 based processor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ A...
Solved Audio service not running in Sound & Audio
Hello, i installed windows 8 CP a few days back and i have been facing quite a few problems. The main one being the audio service not working. I tried a lot of solutions that have been given on the internet but its to no avail. When i try to start the windows audio service from the services screen,...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
