Using TV as audio device
    Hello,
    I have a GTX 650 and I am using Windows 8 and I am not able use my TV as a sound output.
    NVIDIA Control Panel recognizes the TV as a HDMI sound output but it does not appear in the Windows audio output devices list.
    Playback Devices
    Show Disabled Devices - checked
    Show Disconnected Devices - checked
    NVIDIA drivers up to date,
    Screenshots:
    It used to work on another pc with GTS 250 and Windows 7, it used to appear as "SAMSUNG" in the Windows devices list.
    That is why I think it's a Windows 8 issue.
    Does anyone had this same issue? What can I do to make the TV appear again in the devices list?
    (sorry about the portuguese screenshots)
    Thanks.
    You need NVIDIA HDMI audio. That is not shown. The Video card is the one to supply the HDMI audio.
    In the Sound Playback Panel, RIGHT click in a blank area and then click to show "disabled" and "disconnected" devices. If the NVIDIA HDMI Audio is displayed enable it. If the NVIDIA HDMI audio is not displayed, reinstall the NVIDIA driver and see if that corrects it. The NVIDIA HDMI Audio will also be listed in the Device Manger, Sound section if installed.
    Here is my Sound Playback panel. I have AMD Radeon, but your NVIDIA should have a similar display.
    Thanks for your reply fireberd,
    NVIDIA just released a new driver today.
    Lets see if that solves the issue.
    fireberd,
    Just finished installing the new driver that NVIDIA released today and look at what appeared on my playback devices:
    Thanks man.
HD Audio Device conflict in Sound & Audio
I have Asus Z97M-PLUS as my mobo with Realtek® ALC887. In Device Mgr under Sound there are 2 lines: 1) 'Realtek Definition Audio' ... which is OK 2) 'High Definition Audio Device' is alerted with yellow triangle & exclamation mark. What is that ? Is there some kind of conflict ?
Solved HD Audio Device not working in Sound & Audio
Hi All, I searched the threads but could not find a solution. My High Definition audio device is not working. This is the error message, This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful.
Bluetooth Audio Device in Drivers & Hardware
After update from win8 to 8.1 all sorts of stuff is going wrong. Inside my device manager my bluetooth audio device has an yellow exclamation mark beside it. Tried to update driver but says it's already updated. Let me know what info you need from me and hopefully someone can help me solve this.
audio device in Sound & Audio
does window 8 have an audio output device; I wrote before of 2 audio services that say they running but when you hit properties it is stopped and the other is window endpoint. I do not have any audio output . I could be wrong Lorrry
I have tried lots of things to try to solve the problem, but to no avail. Please if you know anything that will help solve my problem please let me know. Thank you!:D
Thanks for anyone, who helps me :D I have "an old fashion motherboard,, with realtek's VT1818S High Definition Audio 8-Channel soundcard build in to the Asus m4a77 motherboard. Usually with W7 windows i had to install the driver from asus's website... so far when i get to the installation point it...
