Background noise while running any program
    Hello,
    I have a problem with background noise, it's like a "sssssssssssssss" thing.
    It only appears when I have a game open, my web browser or any other program.
    Here's a list of my sound drivers ^
    Any solutions or suggestions on how to fix the background noise?
    EDIT: I just found out that even when my speakers are on 0(or even muted), I still hear the noise.
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    Is your microphone maybe set to sensitive(loud) and maybe your getting feedback... happened to me before when I set cortana up in Windows 10TP.
    Quote Originally Posted by Cliff S View Post
    No it's not it, I tried unplugging my microphone and the noise was still there.
    Bamberg Germany
    copied from your link->
    You're using digital and not analogue I see... Do you have any EM(electro magnetic) sources near by, such as a cell/smartphone a microwave oven(like me in my 2 room apartment) or WLAN? Does a slight repositioning make a difference? I ask because of your edit remark.
    Could be "coil whine". (Google it.) Power supply, video card, monitor, even an SSD can cause it.
    Near my PC I have speakers, a printer and two monitors. My phone has always been on my desk.
    I forgot to mention, before the noise appeared I had a Windows 7, and I didn't have that noise. Because I changed my motherboard, processor and power supply, I had to reinstall windows, so I bought a Windows 8.
    And something else I found... when I disabled the Realtek High Definition Audio driver, from the picture above, the noise was gone, but also my sound.
    Quote Originally Posted by crawfish View Post
    I don't believe that it's "coil whine", because from what I have googled, I understood that the "coil whine" comes from the graphics card, and you hear it directly, while I hear the noise through headphones.
    Bamberg Germany
    Have you tried playing around with the properties, such as turning off enhancements or the advanced tab under exclusive mode turning things on/off? Maybe you'll find something there.
    Quote Originally Posted by Yustic View Post
    Coil whine can be caused by all the things I listed and more, which is easily verified by googling. You might have mentioned in your first post that it's a headphones problem instead of saying that it exists even with your speakers muted. If the hiss is not produced by your speakers to a comparable extent as it is by headphones, it may just be a noisy headphone circuit. If you're plugging into a front jack on the case, try the motherboard jack, and vice versa.
    I tried everything, and nothing helped.
    It's defenetly not a noisy headphone circuit, because I have used these headphones before and there was no noise.
    They are plugged into my motherboard jack from the back, and I can't try vice versa because my front jack doesn't work
Hello When i close the metro app from metro task manager (or whatever it called) or from close button. the metro apps still running in background and i always have to stop them with Windows task manager. It is not happen on Windows 8. i can't understand why Microsoft made this...
Solved Background Noise in Skype. in Sound & Audio
Hi, I've used Skype for the most part without problem since it took over from Messenger. Following recent Skype updates the person I'm connected to receives a rapid repeated sound like a demented Woodpecker which stops while he speaks but starts again when he stops speaking. I can't hear this...
Hi, whenever I open a Metro app like Weather, even after closing it using the red cross in the upper right corner (feature added in 8.1 Update), the app will keep running in the background forcing me to end it with Task Manager. Is this normal?
Hello, every time I start up my laptop this program starts running. I do not know what it is and can't figure out what it's called so I can't close it. I can see it running when I switch between tabs. Here is a screenshot of it in between of Chrome and my desktop: 44540 Does anybody know...
Hi, I occasionally play on my laprop in my front room with my family however when I'm on skype to my friends they can hear my TV and Family louder than I can! Is there any software that can lower the levels of background noise or any tips on how to make it so it's quieter for them?
I am trying to access my company desktop at home. The program runs on 32 bit instead of 64 bit. I was advised that there is a way to do this on Windows 8. Please help. thanks in advance.
ok title says it all im trying to launch an app where its not supported on windows 8 yet. The app launches fine but when i close it and try to relaunch the app i get the error. I know you'll tell me to end the task from the task manager and ill be able to relaunch... i know but i need a fix...
