Sound is not sound in Windows 8.1
    Windows 8.1 64 bit
    From this day I turned on my computer I can't here anything from my computer. Yesterday everything worked properly. Now if I check the sound and the driver I can see this http://thewindowsclub.thewindowsclub...ing.png?b6a4bd but I can hear anything.
    If I make right click to the sound button in the right down corner and select "troubleshooting audio" it seems there is a problem but it can fix it.
    How can I fix it?
    windows 8.1
    try to scan your pc for any virus maybe. i am not an expert or anything its just my opinion try first scan "quick scan" if nothing pops out try to use full scan but it will take a while 1:30h to 2h depending how much files u got it may be more than 2 hours depends
    or try back up your pc dunno don't listen to me for that one
    windows 8.1
    i got already set problem for me check out my threat
    Windows 8.1 64 bit
    To be honest I have unistalled the AVG trial antivirus I had because I though it made it.
    I will try to install it and run the scan.
    Thank you very much for your answer.
    windows 8.1
    if the scan doesnt help then i dunno maybe wait for better respond from professionals and i am still waiting for the reply from my threat
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
REALTEK AC97 sound driver installed Working fine!..showing status working but no sound:cry:..after updating PC to win 8..worked well for Win 7..Need Help..:zip:
