Headset microphone recognized but not receiving input
    I currently have a Sennheiser PC 360 that I used on a previous build, which I paired with a ASUS Xonar D1 sound card on Windows 7. I recently put together a new build using Windows 8.1 and now the mic no longer works. I receive audio output through the headset speakers just fine, but the mic acts as if it's muted.
    I assumed it would be the sound card, so I tried using the motherboard jacks. Again, the headset speakers work just fine but no input is received through the mic. Windows does acknowledge when the mic is plugged/unplugged, if that helps at all.
    I tried uninstalling the drivers and letting Windows install the drivers, as well as Windows Troubleshooting (Mic not working on computer Windows 8.1?) to no avail. As far as I know, the drivers are also up to date.
    Recording Devices, all devices shows (including disabled). Mic is currently plugged into the Xonar D1 sounds card ports. Notice that the input bars do not recognize any transmission (mic is not muted).
    In case it was a sound card issue, I used the motherboard integrated sound, using the latest Realtek drivers. Windows recognizes when the mic is plugged in and when it isn't, but like with the sound card, no transmission is recognized either way.
    Realtek Drivers:
    I tried messing with a few options, and I noticed the mic "transmitted" when I enabled the 'Monitoring' option. The mic now appears to transmit, but it's just high pitched feedback-like sound. Nothing I say through the mic is actually transmitting.
    I tried a few things like enabling 'Listen to this device', checking the software that came with the Realtek and Xonar drivers. I even tried contacting MS help, but they said it would require a more intensive troubleshooting which would require a subscription ($99 for 100 days of unlimited help... no thanks).
    Any help would be appreciated!
    It sounds like a potential problem with the headset and the 5VDC that is required by the microphone to work.
    Do you have access to another PC, even a friend's, that you can try the mic on, to make sure its still working.
    A side note, although I don't think it will help your current mic problem. The Stereo Mix is normally set at the Default Recording device. With Stereo Mix set any input device that is connected and used will be heard (used by programs). You also need Stereo Mix if you ever want to record audio (music) from the Internet.
I've been looking everywhere for a solution to this: Headphones Working Fine, Mic is not. The Problem: Asus Laptop with Windows 8.1 with only one audio input won't read Turle Beach X12's Description: 1. The Internal MIC works fine and it works everytime even when I plug in an external one....
So the other day i bought a Logitech for 15 and i get home to recorded my voice but my laptop wont pick up my headset..Like it knows its been plugged in etc and will even play sound through the headset but can seem to get it to pop up on my microphone bit! Could someone help me please?
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
I only just bought a new computer with Windows 8.1 on it. (SO not impressed with this OS.) Anyway, I'm trying to set up all my externals. I have an external microphone I use through a Tascam US-200 audio interface. It has the ability to record in stereo and I have done so for some time using...
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
Hi, I wonder if there's a way to make my own voice audible in the speakers/headphones when using a microphone? I also have RealTek HD Audiomanager installed, since I have an ASUS board. Could this be done in Windows?
