Buzzing noise whenever in games
    Windows 8.1 Pro x64
    Whenever I start playing a game, no matter what game, I get weird buzzing feedback from my headphones or speakers, depends on what I use when I play. They both make the same noise at the same places (certain menus, while in-game, etc).
    I also can't make my built in mic on my earphones to work. I believe that's all somehow connected since it worked flawlessly on Windows 7.
    I'm starting to regret installing 8.1 but I don't wanna go back because I'm lazy. I'm going off topic...
    I tried installing, uninstalling different version of Realtek HD Audio drivers. Whenever I'm uninstalling the built-in my I was talking about starts working, but then I restart my computer and it stops working.
    On the other hand, I have a good headset by Razer, which the microphone of these headphones DOES work. I don't know what to make of this.
    Anyway, in conclusion: Weird buzzing feedback while in-game, earphone's mic doesn't work, headphone's mic does. I really just wanna solve the buzzing feedback thing, thanks.
    Windows 8.1 Pro x64
    Can anyone please help?
    Trnava
    Win 8.1.1 Pro x64
    For starters disable all recording/microphone devices to see, if the issue is microphone related.
    Windows 8.1 Pro x64
    Quote Originally Posted by TairikuOkami View Post
    disabled. Not mic related.
    Windows 8.1 Pro x64
    Is the buzzing ONLY with games? Does other PC audio, or playing a commercial audio CD work OK?
    What is the Razer headset? USB?
    Windows 8.1 Pro x64
    Yes, only in games. I don't play CDs on my computer but whenever I listen to audio, or to Youtube videos, everything is okay.
    The headset is Razer Kraken, but it happens when I play with speakers, so it doesn't has something to do with the headset.
    But, I was wondering if the Razer was USB connected or connected to the headset and mic jacks. That does make a difference in troubleshooting, If the Razer is USB connected, that means it is digital from the PC and DOES NOT use the PC sound card and thus it throws the problem back to something other than the PC's sound card.
    Windows 8.1 Pro x64
    they are connected with a regular audio and mic jack.
    Also, I didn't have this problem on W7.
    I see you have Conexant audio and SoundBlaster audio both showing on your Sound/Recording panel. Having both can cause conflicts (and who knows what else). If you are using a SoundBlaster sound card, disable the on-board (Conexant) in the BIOS. This may not fix your problem but will eliminate any potential.
Whenever i plug in my headphones, i hear a buzzing noise. its not the headphones problem, i tested them on other devices and there was no problem. I even changed speakers but i still have the prob, Please Help, ty. :(
so yesterday i got a random blackscreen and my headset came with a buzzing noise,while i was watching youtube. there were no bumpfile nor anywhere in event viewer were it said something had crashed. ive took the card out and made sure that everything was plugged well in. today it happend again...
Freezing/Buzzing when playing games in BSOD Crashes and Debugging
Hello! As the title says whenever I'm playing a game it'll randomly freeze for a couple seconds and buzz/loop the current sound through my speakers. Sometimes it won't recover and I'll have to shut off my computer manually. Sometimes after a long freeze it will say Display driver crashed but...
Hi everyone, I have an interesting problem: On my laptop (Lenovo Y510p) I can hear a buzzing/whistling/noise sound while my headphones are plugged in. The problem goes away when I mute my sound, but this buzzing can be heard while booting as well. This led me to believe that my problem is...
I have an ASUS LED monitor and an MSI motherboard. When the computer goes into hibernate the blue LED indicator on the face of the monitor blinks. When it starts blinking there is a slight buzzing noise that is emitted. Since my computer is in my bedroom I was hoping to be able to change this so at...
Irritating buzzing noise in Drivers & Hardware
Seem to be plagued with problems at the moment. Have just fixed one and now the Sandy Bridge is making a fairly loud buzzing noise a bit like a doorbell being pushed. It is fairly intermittent and the sound lasts for a few seconds or for a minute or so. It doesn't seem to be related to anything I...
buzzing sound and some lag in Performance & Maintenance
I need help ,some times I get this low buzzing sound in windows 8 while playing audio/video files and while gaming , It only happens for a couple of seconds , 2-4 seconds and then everything goes back to normal . this happens a lot of times . I'm using windows 8 pro 64 bit running the os...
