Playback audio through both inbuilt and external speakers.
  1. #11
    Windows 8.1 Single Language 64-bit
    The installer prompted me to follow all of the above steps, in that order, and I did. So I'm not sure what's going on...
  2. #12
    There are cases of specific hardware not allowing some options. For example, some PC vendors do not allow the users to set the Stereo Mix as the default recording device (a concession to DRM (Digital Rights Management). This sounds like something Dell may have done.
    Suggest you repost this on the Dell Laptop forum and see what they say there. I've been gone from the Dell forums for several years and not up on the latest Dell models and what their options.
    http://en.community.dell.com/support-forums/laptop/
  3. #13
    Ok thanks. I will do that and will post here if I get an answer. Thank you for your help!
  4. #14
    Forever West
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    Something I didn't see mentioned on this subject is the physical action of plugging in speakers or headset that automatically disables the onboard/built-in speakers. Have seen that on most Notebooks but did see a Notebook the other day that had 2 headphone jacks, presumably for sharing music being played. In most cases using a splitter/Y-cable would help in using external speakers plus headset.
  5. #15
    Hi Berton, thanks for your concern but I have a splitter which I would use if I had speakers. What I want to do is play music through both plugged in headphones and built in laptop speakers (as they are the only speakers that I have). However, as I did mention in my original post, when I plug in headphones, sound automatically plays through them and not though the built in speakers.
  6. #16
    Forever West
    What you described is perfectly correct. It's the way the headset socket is made, push a plug in it and the built-in speakers get disabled. There's nothing one can do about that as it's all part of the motherboard. One thing you might look at is Bluetooth speakers if your Notebook has the Bluetooth Wireless adapter, usually part of the Wi-Fi adapter. There are some speaker sets that have a headset jack but it functions the same way as the headset jack on a Notebook.
  7. #17
    It can't be the way the socket is made. According to fireberd there is an option to change it on his/her PC
  8. #18
    Forever West
    Then you will need to contact the maker of your Notebook to ask how to do it with your particular model. I have a number of Notebooks I've resurrected plus a couple of I've bought and they all work the same way, the brands are Dell, HP, Gateway, ASUS, Acer, Panasonic and Toshiba. My Netbook and Tablets work the same. Can't say what the PC you referred to can do, see no information about it.
  9. #19
    According to a man on the Dell forum Dell laptops do not have a Realtek Audio Manager. Instead you get a Dell Audio Manager that seems to be based on the Realtek Manager but is much less useful. He says as far as he knows there is no way to do what I want.
  10. #20
    That's what I suspected. Sorry to hear that it can't be user modified like the regular RealTek HD Audio Manager panel.
    But, thanks for the feedback and info. I'll keep it in mind if someone with a Dell posts about this again.
Hey guys. I discovered that besides VLC player on my laptop all the other video player are not able to work properly (meaning,, Windows Media Player 12, Cyberlink PowerDVD12 and WMPC are able to play only the audio, but not the video, it's just black screen),, BUT with VLC is no problem playing...
Windows 8.1 Genuius SW-G2.1 1250 external speakers ASUS K56CB laptop When tested on other devices, the sound system blows the roof off. On my laptop, it doesn't (max level on computer controls, media player and speakers knob is lower). I'm pretty sure it's not the soundboard, but I've...
i cannot see my graphic equaliser for audio playback - not in the music player but in general. example - i am watching something on youtube and want to adjust the audio but within my sound options i dont see graphic equaliser at all . i done have a dedicated sound card yet but until i do i need...
Checking my audio quality levels, I noticed my default setting was 24bit 48000hz (studio quality.) Is that a setting I should continue using? The only sound output device i'm using are only a pair of Skullcandy ear phones, in-regards to that i'm assuming such a level isn't needed for playback....
HP ENVY 20-d094 TouchSmart Desktop How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ... AND NOT have it over-ride the BEATS audio.? Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF) Is there a way to...
Two programs are creating audio outputs such as a game program and iTunes, I desire to send the game program to my headset while remain the iTunes audio to my default playback device, speakers. I am wondering if there is audio management software. Similar to how if I am on Skype I can...
