HDMI audio "not plugged in" error for ACER Aspire V3-572PG
    I recently purchased an ACER Aspire V3-572PG computer and when hooking it up to my receiver, or TV, via HDMI I cannot get audio to play.
    I have tried going into Control Panel >> Sounds and setting HDMI as default but it seems that the system does not even recognize that the HDMI is plugged in. .. at least not the audio component, as the video is working fine.
    It seems that I have all the latest drivers (Windows High Definition Audio Device; 6.3.9600.16384; 8/22/2013 ... Realtek High Definition Audio; 6.0.1.7300 7/22/2014), with the relevant driver apparently being the Windows High Def Audio Device driver. I have downloaded more recent drivers from Windows Update Catalog but when I try to update them (via Device Manager) I get the message "the most recent driver is already installed."
    The HDMI cable does not appear to be an issue, as it was working with the previous laptop and both cables have the same problem.
    Any viable solution would be greatly appreciated. I am going to try playing audio via the headphone jack but the HDMI port is preferred, to minimize the # of cables.
    Thanks in advance,
    Rob
    For anyone else having this issue, I happened to find a solution here: Digital Audio (HDMI) shows not Plugged In Windows 8.1 - Microsoft Community .. specifically, I used the Intel update tool to update the graphics driver. I somehow managed to install a newer Realtek driver (6.0.1.7378) before doing this, but it wasn't working until I updated the graphics driver. Now HDMI is plug n' play for both audio and video.
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
Hi Everyone, First post here, allow me to thank you in advance for your good help - people like me who have limited information on diagnostics and repair owe a deep debt of gratitude for your service. :) I own an Acer Aspire V5-571P-6815, which has put up the Recovery blue screen of death,...
Windows 8.1 Pro here The icon of "Safely Remove Hardware and Eject Media" appears even when i not have any devices plugged in. And if i click it it shows below the "Open Devices and Printers" an item with text "..." which is disabled..:mad:
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
Hey Guys, My VIA drivers won't install because it can't find the device. I'm trying the driver from the Biostar Website. I've tried the ones from the via website but those don't work either. I get nice clear audio but i can't configure my drivers so I can get my sub woofers working. Links...
can't install VIA HIGH DEFINITION(HD) AUDIO DRIVER in Windows 8 Dev. Preview x64.tried 4 to 5 different versions.but none of them would install.i can't get FRONT PANEL HEADPHONE output with default Windows audio.speakers works fine. error : ...
