No Sound from Sub Woofer
    My subwoofer won't emit any sound. I have it plugged into the correct port on my Mobo but still no luck. My PC is hooked up to a 42" (LCD) HDTV via HDMI so I do have sound coming through the television speakers but no bass emitting through the sub. The sub has a output on it so it can be used with satalite speakers but I dont have them hooked up because I dont need them. I hope that not having them hooked up is related to the problem. Can anyone offer any advice to assist me?
    Thanks in advance.
    Win 8 64-bit
    Not sure how it works in conjunction with HDMI/TV, but with my computer speakers they have two leads that need to be plugged into the motherboard connections. Green (line out) and black (sub). Although in your pic it seems to have yellow/orange as sub, so I'm not sure why it's different (possibly country differences or motherboard differences).
    Quote Originally Posted by ARC1020 View Post
    Not sure how it works in conjunction with HDMI/TV, but with my computer speakers they have two leads that need to be plugged into the motherboard connections. Green (line out) and black (sub). Although in your pic it has yellow as sub(?), so I'm not sure why it's different.
    Yeah I tried the yellow (sub) input jack but that didn't work either. I'm stumped....
    Thanks for at least responding though.
    When you use HDMI, Windows automatically changes the Default Audio Playback device from the "Speakers" (PC Sound card) to HDMI and thus you will not have any sound from the PC sound. Windows only allows one default audio playback device.
    Thank you for the clarification.
    Hafnarfjörður IS
    Hi there
    That actually shouldn't be a mega problem -- most cheaper Sub Woofer systems have the Sub Woofer connected via the Speaker system and not the main Computer. More expensive sound systems will have specific connections like 2.2 / 7.2 etc cinema systems. If your computer also has an Optical out then the Cinema amp will convert this into the analog sound streams for the speaker combinations (3/5/7.2 etc).
    On your sub woofer there should be a cable which connects to the speaker system if the system is part of a set. If it's a separate sub woofer you'll need to connect via a separate sound card / amplifier.
    Cheers
    jimbo
    Windows 8.1 Update 1
    I think the source of the problem is clear. You cannot use HDMI sound output and speaker output at the same time. If you want to keep using HDMI for sound the only way how you will be able to make the subwoofer work is to connect the subwoofer to the tv (if there is a subwoofer output). If that's not possbile you will have to switch over to playback through the mainboards speaker output. But this would mean that would have to connect the satelites too in order to get decent playback. Otherwise the only thing you would hear is what the subwoofer emits.
    Hafnarfjörður IS
    Hi there
    There might be another option here too.
    Sometimes the HDMI device (in fact usually) will ALSO have at least a Headphone output. Plug that into the speaker system if the speakers are typical computer one's (external power driven). If you are REALLY lucky the HDMI device will also have an OPTICAL out - but then you need a separate amplifier to drive the sound.
    Check the SOUND output of the HDMI device -- switch say to TV (if it has a built in tuner) and see if there's any sound output.
    Cheers
    jimbo
    Quote Originally Posted by jimbo45 View Post
    Hi there
    Cheers
    jimbo
    Ok, that worked! Plugging the sub (as well as the satellite speakers) into the TV's headphone output worked. I now have bass from my sub.
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
