Windows 8 choppy audio problem
    kelowna
    i need help my audio is really choppy for some reason, can someone hep me fix it ?
    kelowna
    hi i need help with my audio, its really choppy, I use realtek hd audio manager, and it doesnt matter if my headphones are plugged in or its my speakers, my headphones work perfectlyfine on my mp3 player but not my computer, i need some hepl pleas
    Audio problems such as what you describe are hard to pin down. There is no "one fix" for the problem. Each one has to be handled individually.
    First step, run the Resplendence Latency Mon program and see what it pinpoints. Resplendence Software - Advanced System Tools and Developer Components
    Some known causes include wi-fi, audio drivers, video drivers. Please fill in the "My System Spec's" so we have an idea of what your PC hardware is. It helps us to try and help you.
    kelowna
    Hi, Sorry to waste your time, but i figured out what the audio problem was, it was my mistake, i had the setttings set to hd and not studio in the realtek hd audio manager, sorry about wasting your time. but i figured it out . thanks so much for the help i really appreciate it . again, sorry. /thread
    That should not have anything to do with it. Mine is set to the CD Audio standard, 16 bit/44100Khz. I do not have any stuttering.
This is like a ghost in a machine issue of mine now, and it's been for a few months, killing me at this point as I can't figure out what it is... what happens is that while I'm working on the computer, everything is fine. As soon as I step away for a few minutes, and the PC is idle, the audio...
Windows 8.1 Audio Problem in Sound & Audio
I recently got a audio technica atr-2500 microphone and it has a headphone jack to listen to what your recording. But I don't think that has anything to do with it. The real problem is my sound is to loud, I would usually keep it on 32 but now I keep it on 8 percent. I have Realtek HD audio as the...
So, I've been running Windows 8 for a year, never had any major problems, till now. When I'm watching any videos, say a 5 minutes video, I watch 2/3 of them, and the Audio suddenly stops working, at all. There's no sound. Volume bars doesn't show any sound generated, too. So, first I...
Hey all I just reinstalled a fresh copy of Windows 8.1. Everything works fine, apart from the audio. When I play any sound effect, I hear a small "pop" (when the audio channel is initialised), and then about a 0.5s delay before I can hear anything. By this point, I've missed the first 0.5s of...
audio problem in win 8 in Sound & Audio
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
