Problem with Audio Devices Connecting/Disconnecting
EpicLightning
United States
I have noticed that when a program or something using sound is running, if I unplug my speaker device and then either plug it back in, or plug in a new audio playback device, the sound will stop working altogether and within a matter of about two minutes, the entire computer will become unresponsive to the point that I have to manually restart it via pressing the button. This problem did not occur in Windows 7 (previous version I had); so therefore, I know it is not a problem with the CPU.
    Windows Eight Consumer Preview
    eMachines EL1850
    Intel Celeron
    ACPI x64-based PC
    2048MG RAM
    Intel G41 Express Chipset
    Realtek High Definition Audio
    DELL ST2010
    1600x900
    Intel Celeron; C-drive
    Standard PS/2
    Microsoft PS/2; Tablet Mouse
    20.69Mbps
Hi,
I'm not really understanding what you're doing. Why would you bother touching any playback settings when it is playing well to begin with? (I ask because the answer will likely influence my response.)
Are you talking about physical speakers/headphones or different audio interfaces running on the computer?
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hello, and a late welcome to EightForums. Download the drivers for your audio card and reinstall them. If it carries on, it is a hardware problem indication that the hardware is incompatible with Windows 8. BTW, how old is your computer?
    Windows 11
