Audio stops when plugging earphones / speakers to 3.5mm
    Windows 8.1 64-bit
    Hello,
    I have a Lenovo G510, and many times (most of the times) when I plug earphones or speakers to the 3.5mm jack, the audio stops, and a red X appears on the Speakers icon in the notification area, and I have to press Solve problem and then it detects that the speakers stopped working (I will try to get the accurate error next time), and only then the audio returns.
    ( It's a combo jack - speakers and mic - why do they do it, I have no idea )
    What can I do?
    (I did factory reset and that did not help)
    Thanks
    Are you using the correct sound driver from Lenovo?
    The 8.1 driver can be downloaded from Lenovo here
    Laptops and netbooks :: Lenovo G Series laptops :: Lenovo G510 Notebook - Lenovo Support (US)
    Windows 8.1 64-bit
    Thanks.
    should I download and install it? Or there's a way to check if it's already the one that I'm using so that I won't have to install it?
    *Edit : I went to Device Manager and clicked on Audio inputs and outputs and pressed on Update driver software and it says that Windows determined that I have the latest drivers (however it doesn't say if they are the correct ones )
    That Windows tells you that you have the latest isn't always correct.
    What, exactly, is listed in the Device Manager, Sound Section?
    Windows 8.1 64-bit
    Audio inputs and outputs:
    -Microphone (Conexant SmartAudio HD)
    -Speakers (Conexant Smartaudio HD)
    That is not what is in the Device Manager
    To access the Device Manager, go to the Desktop, then Hold the Windows Key down and press the Pause/Break key. When the Panel comes up, Device Manger will be in the list in the upper Left of the Panel.
    For an example, here is what my Device Manager shows. Its from Win 7, but Win 8 is the same.
    Windows 8.1 64-bit
    Oh I did look at device manager, but I looked at the wrong title "Audio inputs and outputs".
    Under "Sound, video and game controllers" I get:
    -Bluetooth Audio Device
    -Conexant SmartAudio HD
    Update: I installed the new drivers from the Lenovo website and it looked like the same version but I proceed with installation anyway, I hope it will help. if the problem appears again I will tell you
    *Another update: after I clicked "update driver" on "Conexant SmartAudio HD" under "Sound, video and game controllers" it actually did install something so I hope it worked
Hi, Wondering if anyone can help me solve why my audio goes every time I plug in my mouse or external hard drive into one of the usb ports. The only way I can get audio back is by restarting the computer. I'm running Windows 8 on ASUS UX32VD. I've gone into Sound settings, Communications...
Hello, I just bought a new pc and received it today, and i plugged my headset in to check if i hear audio from both speakers and headset but its not working. When i plug my headset in i only hear audio from my headset and not the speakers. Ive been googling and found something about it but with...
I have a computer i built first one in a long time and its been about 5 years since i have windows. I have the issue that if i boot up it will play audio over hdmi to my tv i have hooked up fine but when i plug in headphone to front jack they work fine. when i unplug my headphones it wont play over...
HP ENVY 20-d094 TouchSmart Desktop How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ... AND NOT have it over-ride the BEATS audio.? Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF) Is there a way to...
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
