Audio stops when plugging earphones / speakers to 3.5mm
mibaup
Hello,
I have a Lenovo G510, and many times (most of the times) when I plug earphones or speakers to the 3.5mm jack, the audio stops, and a red X appears on the Speakers icon in the notification area, and I have to press Solve problem and then it detects that the speakers stopped working (I will try to get the accurate error next time), and only then the audio returns.
( It's a combo jack - speakers and mic - why do they do it, I have no idea :sarc: )
What can I do?
(I did factory reset and that did not help)
Thanks :party:
    Windows 8.1 64-bit
    Lenovo
    i5-4210m
    4GB RAM
    AMD Radeon R5 m230 2GB + Intel HD Graphics 4600 (Switchable Graphics)
    15.6"
    1366x768
Thanks.
should I download and install it? Or there's a way to check if it's already the one that I'm using so that I won't have to install it?
*Edit : I went to Device Manager and clicked on Audio inputs and outputs and pressed on Update driver software and it says that Windows determined that I have the latest drivers (however it doesn't say if they are the correct ones :cool:)
    Windows 8.1 64-bit
    Lenovo
    i5-4210m
    4GB RAM
    15.6"
    1366x768
That Windows tells you that you have the latest isn't always correct.
What, exactly, is listed in the Device Manager, Sound Section?
Audio inputs and outputs:
-Microphone (Conexant SmartAudio HD)
-Speakers (Conexant Smartaudio HD)
    Windows 8.1 64-bit
    Lenovo
    i5-4210m
    4GB RAM
    15.6"
    1366x768
That is not what is in the Device Manager
To access the Device Manager, go to the Desktop, then Hold the Windows Key down and press the Pause/Break key. When the Panel comes up, Device Manger will be in the list in the upper Left of the Panel.
For an example, here is what my Device Manager shows. Its from Win 7, but Win 8 is the same.
Oh I did look at device manager, but I looked at the wrong title "Audio inputs and outputs".
Under "Sound, video and game controllers" I get:
-Bluetooth Audio Device
-Conexant SmartAudio HD
Update: I installed the new drivers from the Lenovo website and it looked like the same version but I proceed with installation anyway, I hope it will help. if the problem appears again I will tell you :)
*Another update: after I clicked "update driver" on "Conexant SmartAudio HD" under "Sound, video and game controllers" it actually did install something so I hope it worked :D
    Windows 8.1 64-bit
    Lenovo
    i5-4210m
    4GB RAM
    15.6"
    1366x768
