Cannot remove VIA HD Audio Deck icon from Control Panel
    Helsinki, Finland
    Windows 8.1 Pro x64
    Hi,
    I can't seem to find a solution this anywhere online.
    It's not been an issue in terms of system performance, but it's just annoying. And also a little weird.
    I changed motherboards a while back. Old one had VIA audio. New one has Realtek.
    Uninstalled the old drivers and installed new drivers when I made the hardware switch.
    Current system works fine in every way, including the Realtek Audio.
    The thing is, there is still an icon for "VIA HD Audio Deck" in control panel. When I click it, it tells me "application not found".
    I have tried the tip to right-click to create a shortcut on desktop, and then find the actual file location from the new shortcut's details, but it does not show a location for the VIA cpl or other files, other than All Control Panel Items. Can't figure out how to get it out of there.
    I have tried installing the old VIA drivers and uninstalling, no joy.
    Anyone have any ideas on this?
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    First make a restore point then search using "Find" in RegEdit for all the keys for VIA HD Audio Deck and delete them.
    Bamberg Germany
    Quote Originally Posted by Cliff S View Post
    Sorry I forgot: And reboot.
    Helsinki, Finland
    Windows 8.1 Pro x64
    Thanks for the quick reply.
    Yep, once I had actually found the damn thing (and a whole load of other VIA audio junk) and deleted it, it has now disappeared. Thanks for pointing me in the right direction. I'll mark this solved now.
    Cheers
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
Hello, I need help removing the SmartAudio application from my Control Panel. Every time I click on it, it says "failed to initialize" - I no longer have it nor do I need it. I would just like to get rid of it from Control Panel, it's not slowing my system down or anything, it's the OCD in me that...
How to Add or Remove Control Panel from Navigation Pane in Windows 8 and 8.1 This tutorial will show you how to add or remove Control Panel from the navigation pane of File Explorer for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. This includes Control Panel for when...
How to Add or Remove Control Panel in This PC in Windows 8 and 8.1 This tutorial will show you how to add or remove the Control Panel folder in Computer (Windows 8) or This PC (Windows 8.1) in File Explorer for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. You must be...
There is a weird thing in my control panel called Akami Netsession interface control panel, how can I remove it? It says Application not found when I click it. Screenshots: Screenshot by Lightshot Screenshot by Lightshot
How to Add or Remove "Task Scheduler" from Control Panel in Windows The Task Scheduler enables you to automatically perform routine tasks on a chosen computer. With this service, you can schedule any program to run at a convenient time for you or when a specific event occurs. The Task Scheduler...
Add or Remove Catalyst Control Center Taskbar Notification Area Icon in Windows If you have AMD video drivers installed, then this tutorial will show you how to add or remove the Catalyst Control Center icon from your taskbar notification area in Vista, Windows 7, and Windows 8. EXAMPLE:...
