Microphone Doesn't Work When Headphones are in Audio Jack
    Microsoft Windows 8.1 64-bit
    Well, I used my microphone on my laptop once to call a friend on Skype. Everything worked fine, even with my headphones plugged into the audio jack. But the day after, I try and do the same but my microphone isn't even working. After lots of frustration and trial and error, I find that it's the headphones being plugged into the audio jack that's causing this. Does anyone know how to fix this? Something simple, right? I use my headphones when I'm calling anyone. I don't want anyone to hear and I hate headsets with a burning passion. They make my head hurt, so is there any way to fix this? Thanks (:
    Try refreshing the audio. Go to the device manager, RIGHT click on the entry for the RealTek HD audio, then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the audio. This fixes any Windows/Audio corruption and many other problems. If you are lucky it will take care of your problem.
    Thank you! I'll try that!
    Sorry for the double post but where on earth is this? I've searched on Google but not many answers. Help?
    The Device Manager can be accessed by going to the Desktop. Hold the Windows Key down and then press the Pause/Break key. When the panel comes up, the Device Manager can be accessed from the Task List in the upper left of the panel.
    Here is mine from Windows 7 but my Windows 8.1 is the same.
    Thanks! I tried that, and it asked for a restart. I did that. Needed to re install, and such. Still the same problem
    You should have an entry for the Microphone in the Device Manager, Sound section. Do the uninstall/reboot/reinstall with that and see if that helps.
    If not, do you have a System Restore point that is BEFORE the problem happened? (when it worked correctly).
    I tried looking for that, uninstalled but I have no idea where to go from there, as I can't find where to re install it.
    Uh. I have no idea what that is. Also, to note: I'm now getting severe issues with audio. I can't use Windows Media Player. It keeps crashing, never works in the first place and causes my laptop to glitch and spazz. I also have issues when trying to read MOV files. The computer hasn't liked it, so I can't click it without my screen glitching and going to the view in the Windows 8 not desktop main screen. Can't edit it, can't remove it. The laptop just hates it and it keeps glitching out and causing mayhem. What on earth is going on here? Do I have another faulty laptop?
    This suggests more problems with the PC than just the audio, and the audio problems may just be a byproduct of what is causing the other problems.
    I would more suspect a Windows OS problem than a hardware problem with the PC. It may take a "factory reset" (reinstall) to correct everything.
    One other comment, and I don't think it has anything directly to do with your problems but I see you have the 64 bit OS but only 4GB of RAM. The main benefit of a 64 bit OS is that it can address more than 4GB of RAM. A 32 bit can only address a little less than the 4GB. However, a 64 bit OS uses more of the basic memory than a 32 bit, thus you have less memory available for programs. Also, how old is this PC and did it originally come with Win 8?, I don't recall many new PC's with a Celeron CPU.
    I thought so. Oh, whew! So, it's more likely an install problem? How come that happened, then? Is it quite common? How would I get to this Factory Reset? Will I have to move everything I need to my USB stick, or doesn't Factory Reset delete everything?
    Oh, would that be a problem? The OS and RAM thing? My laptop is only just under a month's old. Yes, it did originally come with Windows 8. Is that bad, having a Celeron CPU?
Page 1 of 2 12 LastLast
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
Hi I have a Logitech 540 and another Logitech 3XX USB headphone & mic and I'm wondering can I easily configure them to both work simultaneously? The application is for a Google Voice call. So two people can conference call another person from one computer.
Headphones or Jack problem? in Sound & Audio
When I connect the headphones "headphones" are disabled ... and when I try to log in does not work.and skype are connected: the MicroPhone but not going to speak..but i can hear...excuse me for my bad English ... I just want to talk on skype and I can not ...:) I have connected the speakers to the...
I have an HP 2000-2b10CA and I bought it FIVE DAYS AGO!! I was checking if everything worked so I shot a video and when I played it back I heard nothing! Then I found out it was my mic! I searched online and a lot of people told me to go to the settings and set it as my default device but IT...
Hello, I have a Toshiba Laptop c660 with windows 8 professional installed. I can`t make the jack for headphones to work. The jack is not broken because it works on Ubuntu. I installed the driver for my soundboard. Didn`t worked. I unistalled it and i let windows chose the best option for me...
Hi all, I have tried the drivers from RealTek and also the drivers from MSI. (My motherboard is MSI P35 Platinum). Driver installation / removal always proceeds without any errors. But the Audio Service just can't start. In some places, the RealTek device reports status "working properly"....
