Microphone Doesn't Work When Headphones are in Audio Jack
  1. #11
    You should have a procedure to restore the PC to the original settings when you first got it. If you don't have the instructions, Toshiba most likely has that on their web site. A "Factory reinstall" will delete any user data so back that up on some removable media first so you can recover it.
    A Celeron is at the low end of the Intel CPU line. I didn't even know Celeron's were still being sold. Celeron processors, of some sort, have been sold since the Windows XP days on entry level (low price) PC's.
  2. #12
    Microsoft Windows 8.1 64-bit
    Okay, thank you! What if this doesn't do a thing? How certain are you that this will fix it? Oh, right. So, I have a bad CPU, you're saying?
  3. #13
    No, I'm not saying the CPU is defective. Just that its not a high powered CPU like the Intel i3, i5 or i7's.
    No guarantee the reinstall will fix it. But if you call the PC vendor for support most likely the first thing they will want you to do is the reinstall. If the reinstall doesn't fix it, the next step is the vendor support. Only the PC vendor's support can get whatever is wrong corrected under warranty, since this is a new PC.
  4. #14
    Ah, okay. Thanks. I get it.
    Okay, I'll try it. I'll mark this as Solved and if still no luck, I will ring them. Thanks for all your help!
Page 2 of 2 FirstFirst 12
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
Hi I have a Logitech 540 and another Logitech 3XX USB headphone & mic and I'm wondering can I easily configure them to both work simultaneously? The application is for a Google Voice call. So two people can conference call another person from one computer.
Headphones or Jack problem? in Sound & Audio
When I connect the headphones "headphones" are disabled ... and when I try to log in does not work.and skype are connected: the MicroPhone but not going to speak..but i can hear...excuse me for my bad English ... I just want to talk on skype and I can not ...:) I have connected the speakers to the...
I have an HP 2000-2b10CA and I bought it FIVE DAYS AGO!! I was checking if everything worked so I shot a video and when I played it back I heard nothing! Then I found out it was my mic! I searched online and a lot of people told me to go to the settings and set it as my default device but IT...
Hello, I have a Toshiba Laptop c660 with windows 8 professional installed. I can`t make the jack for headphones to work. The jack is not broken because it works on Ubuntu. I installed the driver for my soundboard. Didn`t worked. I unistalled it and i let windows chose the best option for me...
Hi all, I have tried the drivers from RealTek and also the drivers from MSI. (My motherboard is MSI P35 Platinum). Driver installation / removal always proceeds without any errors. But the Audio Service just can't start. In some places, the RealTek device reports status "working properly"....
