Sound crackling/popping
  1. #11
    What is the brand and model/watts of the power supply?
  2. #12
    Welcome to Seasonic USA
    520w model.
    I bought everything new except GPU and RAM. Month later I bought new GPU also, now only RAM exist from old setup. But I think my old computer still has same crackling problem, just bought some cheap gpu and ram for it after building this one.
  3. #13
    The power supply is probably not the problem.
    With both PC's doing the same thing I wonder if some software you have installed is causing this. Did you try the new PC before you installed anything other than the basic Windows OS and drivers?
  4. #14
    It did same even with only Nvidia driver/AVG/Firefox/steam on computer
  5. #15
    That is relatively quite a bit for a new PC.
    AVG is listed on recording sites as a "do not use". I don't know what all Steam installs.
  6. #16
    Should I uninstall and try without AVG?
  7. #17
    See if you can disable it, without having to uninstall it.
  8. #18
    Hmm, I think you can disable protection but program itself is still on.
    Uninstalled AVG and downloaded some other antivirus, nothing changed.
Page 2 of 2 FirstFirst 12
Recently I started noticing popping sounds at multiple frequencies (mostly higher frequencies) when playing audio. I don't know what caused it, but this is what I already tried: Using a different audio port. Updating drivers. Updating BIOS. Disabled all unused sound ports. Installed...
Hi all, I have read quite many posts so far regarding this issue in Windows 8. It Looks like they have overlooked the Sound skipping problem during playback on different programs and codecs. Whenever one uses Media Player, Spotify or any other audio programs the Sound skipps and crackles. It comes...
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
Sound Popping/Crackling in Sound & Audio
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
So I just installed Windows 8 and decided to play some music, found out that my DPC Lat is huge and I did try disabling some things such as audio drivers LAN drivers etc. Still didn't solve the problem so I'm at a loss at what I'm supposed to do now. Maybe I skipped over certain parts which I...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
