Microphone not being recognized, followed every step
    I've been looking everywhere for a solution to this: Headphones Working Fine, Mic is not.
    The Problem: Asus Laptop with Windows 8.1 with only one audio input won't read Turle Beach X12's
    Description:
    1. The Internal MIC works fine and it works everytime even when I plug in an external one.
    2. When I plug in either external headphone (Headphone's got 2 jacks, green which is for sound and red which is for recording) into the Only ONE audio input there is, Windows gives a popup with its current Audio devices plugged in. The headphones work fine, but it just wont read the MIC. This is what pops up when I plug in the external MIC or headphone.
    3. Now, When I go to the lower right corner and select Recording Devices from the sound panel, it won't show any external or added device when I plug in the new device. It would just show my internal MIC and something called Stereo MIX, but not my Microphone.
    4. Okay, Now when I check Device Manager, and try to update all the Realtek Audio drivers it would just say "everything is latest with latest drivers installed", which is obvious since Windows 8.1 has bundled everything with my laptop.
    5. So, This is basically the problem. I've added everything here in this post, if anyone can find some solution to this that'd be helpful or else I'm going to write a long letter to ASUS to sort their shit straight by making 2 HOLES instead of ONE, since every headphone there is has 2 JACKS.. So, we need 2 HOLES for 2 JACKS.
    I will buy the appropriate audio/mic splitter to use with this headset, but before I throw away any more money I want to get the mic itself working. I belief the first step would be getting it to be recognized on the recording devices GUI...
    Guys, Your Help is Needed!
    What is the specific ASUS model number? I can't research your problem without that.
    A comment not directly related to your problem. Stereo Mix should be set as the default recording device. Then whatever device is plugged in, e.g. microphone, will be used. Stereo Mix is also needed if you want to record any audio from the internet.,
    Model number: ATHEROS/AR5B125
    The AR5B125 is the wi-fi card, from what I find.
    That's the number I have under "model number" on the bottom of my notebook.
    I swtiched my recording device as you recommended but still no luck):
    On the ASUS forum they refer to that as the number for the Wi-Fi card. I tried to find that under the laptop models on the ASUS support site but nothing like that was listed.
    That website told me the model number was at the same location...
    what else could I do?
    If you v oukd link me to this model site I'll just point out mine.
    Found it.
    X550CA-SI50304V
Page 1 of 3 123 LastLast
Log in to Windows with outlook - 2-step verification? in User Accounts and Family Safety
I have been enabling two step verifications on several outlook accounts. I'm asking if there's anything I should be aware of when enabling on an account used to sign in to windows 8? The windows sign in password would be the same etc.
Network install step by step in Network & Sharing
Please edit this if needed or post a better or different document. Thanks Basic rules of networking on Windows (I'm assuming this includes 8, 8.1) 1. Computers need to be in the same WORKGROUP 2. Computers in the same network need to have different IP numbers 3. Computers should be...
Solved 2 step verification and account madness in User Accounts and Family Safety
Has anyone tried this yet? I think they either rolled out a broken feature or Windows 8 isn't able to handle it yet. I enabled it and I could no longer sync my passwords because it wouldn't let me trust my PC anymore. If I click the link in settings under the charms menu, it says the URL is...
I'm wondering, is there a way to enable 2 step verification on gmail, instead of using your cellphone, like use an email instead?
Hi Friends I Windows 7 USB DVDwith Windows 8 ISO fileto my USB transfer . Then put the boot in BIOS on my USB .. After reset, the system was confronted with the image permanently installed Now restart again after the first encounter with the previous picture back to the original setup...
Installation fails after first step in Installation & Setup
I'm running Win8 CP 64-bit. I ran the Upgrade Assistant program & purchased my license/key. I cancelled the download as I already have the RTM from a few months ago on a bootable flashdrive. I boot from the USB drive, choose my location from a standard looking Microsoft dialog, click...
Source: Windows 8 step-by-step installation screenshots leak | Windows 8 Center
