Microphone not being recognized, followed every step
  1. #11
    I went through the entire ASUS manual and the only thing I found is the jack is a combination mic and headphone jack. If a mic is connected it should detect a microphone. If a headphone is connected it should detect the headphone
    It doesn't say what type of plug, but I assume a standard 3.5mm stereo plug (tip, ring, sleeve). An iPhone or PS/4 game plug which is tip, ring, ring, sleeve would not work.
  2. #12
    It is tip/ring/ring/sleeve but is marketed as PC compatible... would an adapter do any good?
  3. #13
    Yes, you can get an adapter that will break out the mic and headphone portions to separate jacks.
    Here is an example:
    iPhone Head Set Cord - Dual 3.5mm Stereo Plug to 3.5mm TRRS Jack - 6 IN | ShowMeCables.com
  4. #14
    Here is an example:
    This can't be it... my jacks meet all the specifications of those ones
  5. #15
    I have the same problem. The microphone I have works on other computers but not mine. the one thing I've noticed different is the selection options when plugging in the mic - headset, headphone, speaker but no microphone is an option. I've tried everything and can't get computer to recognize this microphone. I'm using windows 8, acer aspire e1-510-4413
    I've also tried using USB input adapter and computer recognizes the microphone with that but doesn't work, no sound is picked up. I keep spending money trying to get this to work with no luck.
  6. #16
    I've been on the ACER site but can't find any specs on what type of jack you have.
  7. #17
    I tried StartTech's Virtual 7.1 USB external sound card, computer recognizes it but not the microphone. Why would my selections be limited to headset, headphone and speaker while not offering selection of a microphone yet it's suppose to support microphones. no external microphone seems to work on this computer. If it's designed for a microphone there must be a fix I just can't find it
  8. #18
    Please post a screen shot of the Sound Panel, Recording section.
  9. #19
    I just installed the lastest driver on Acer website and not it won't even recognize speakers so there is no image I can give you
  10. #20
    just did a system restore and took a picture of the selection I get when plugging in my mic
    Click image for larger versionit is suppose to be able to handle a mic as well speaker so why don't I have a mic selection? this is the difference between other computers that this mic works with.
Log in to Windows with outlook - 2-step verification? in User Accounts and Family Safety
I have been enabling two step verifications on several outlook accounts. I'm asking if there's anything I should be aware of when enabling on an account used to sign in to windows 8? The windows sign in password would be the same etc.
Network install step by step in Network & Sharing
Please edit this if needed or post a better or different document. Thanks Basic rules of networking on Windows (I'm assuming this includes 8, 8.1) 1. Computers need to be in the same WORKGROUP 2. Computers in the same network need to have different IP numbers 3. Computers should be...
Solved 2 step verification and account madness in User Accounts and Family Safety
Has anyone tried this yet? I think they either rolled out a broken feature or Windows 8 isn't able to handle it yet. I enabled it and I could no longer sync my passwords because it wouldn't let me trust my PC anymore. If I click the link in settings under the charms menu, it says the URL is...
I'm wondering, is there a way to enable 2 step verification on gmail, instead of using your cellphone, like use an email instead?
Hi Friends I Windows 7 USB DVDwith Windows 8 ISO fileto my USB transfer . Then put the boot in BIOS on my USB .. After reset, the system was confronted with the image permanently installed Now restart again after the first encounter with the previous picture back to the original setup...
Installation fails after first step in Installation & Setup
I'm running Win8 CP 64-bit. I ran the Upgrade Assistant program & purchased my license/key. I cancelled the download as I already have the RTM from a few months ago on a bootable flashdrive. I boot from the USB drive, choose my location from a standard looking Microsoft dialog, click...
Source: Windows 8 step-by-step installation screenshots leak | Windows 8 Center
