recording onto an SD card
    I wondered what the sound quality was like when you record music onto an SD card, so you can play music on other devices with a SD slot. Does anyone do this please.
    Quote Originally Posted by nougart View Post
    Just like recording to any other storage device, ie. HDD or or USB.
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    Exactly. Digital is Digital, either it goes thru or not. Another example would be a cheap HDMI cable is just as good as a n expensive one sound wise. What makes a difference sound wise is sound system hardware and drivers.
    Windows 10 Pro Prieview x64
    Untrue. I bought the absolute cheapest USB 2 stick (3 for 8gb from Asda) so I could put movies on it to watch from my TV box. It couldn't provide the data fast enough. It would just freeze. I copied the exact same data to a slightly better quality SanDisk one and it was OK.
    Quote Originally Posted by adamf View Post
    Video takes heck of more data, specially on HD, even some slow HDDs may have problem, music is much less demanding. Cheap USB memories have problem with USB part, SD cards use built in interfaces. SD cards are also rated in classes by speed and only HD video cameras may need fastest ones. https://www.sdcard.org/developers/overview/speed_class/
    I am using SanDisks flash drives to record my music onto but can't use the flash drives on other devices , except for my laptop. I don't know whether there exists any kind of adapter that I could use?
    Something like this: Amazon.com: eForCity SDHC / SD / MMC Memory Card Reader to USB 2.0 Adapter, Smoke: Computers & Accessories
    .................................. SD cards are also rated in classes by speed and only HD video cameras may need fastest ones. https://www.sdcard.org/developers/overview/speed_class/
    Thanks for the link, so have I understood right that I don't need to get the fastest SD card then if it's just for music CountMike
    Yes sir, that's all it is needed.
    Thanks for that
Page 1 of 2 12 LastLast
I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue. Things I've tried: The mic is not muted and the volume levels are maximized ...
Windows 8 When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone. But I want to record the sound directly from the sound card (or whatever it is). I know its possible, I have done...
Audio Recording Issues in Sound & Audio
I recently purchased a ASUS G750JX-DB71 laptop, and updated from 8 to 8.1 I am having one problem, most likely user error. When I record either audio such as yotube, or itunes radio with either Sound Recorder, or Audacity. the playback is very "tinny" (low level, poor quality, very...
help with screen recording in General Support
whenever i try to record my screen,whatever software and settings i use,when i play back the video it shows on the top half of my screen and the rest is just black,either on windows media player or on the movie maker. heres a screenshot of what im talking about: 30384
I run a triple monitor setup on windows 8 64bit. I was originally on windows 7 but decided to give 8 a try. What i typically do is run a game like world of warcraft on one monitor and then i am using camtasia on another monitor to record streaming video. In windows 7 this worked great because i...
Solved computer recording softwere in Software and Apps
ok i need some smart peoples help i wanna make some game videos for youtube but i aint got the softwere to record my computer does anyone know any good and cheep softwere i can buy from amazon or play.com
It also slows down my computer it appears - The driver that was installed automatically says 2006 IC USB Storage-CFC USB Device this is the hardware ID under USB MASS STORAGE DEVICE USB\VID_1019&PID_0C55&REV_0100 USB\VID_1019&PID_0C55 And under one of the Tabs:...
