recording onto an SD card
nougart
I wondered :think: what the sound quality was like when you record music onto an SD card, so you can play music on other devices with a SD slot. Does anyone do this please.
    Sony Vaio
Just like recording to any other storage device, ie. HDD or or USB.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Exactly. Digital is Digital, either it goes thru or not. Another example would be a cheap HDMI cable is just as good as a n expensive one sound wise. What makes a difference sound wise is sound system hardware and drivers.
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7590 AX V2
Untrue. I bought the absolute cheapest USB 2 stick (£3 for 8gb from Asda) so I could put movies on it to watch from my TV box. It couldn't provide the data fast enough. It would just freeze. I copied the exact same data to a slightly better quality SanDisk one and it was OK.
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
Video takes heck of more data, specially on HD, even some slow HDDs may have problem, music is much less demanding. Cheap USB memories have problem with USB part, SD cards use built in interfaces. SD cards are also rated in classes by speed and only HD video cameras may need fastest ones. https://www.sdcard.org/developers/overview/speed_class/
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I am using SanDisks flash drives to record my music onto but can't use the flash drives on other devices :huh:, except for my laptop. I don't know whether there exists any kind of adapter that I could use? :think:
    Sony Vaio
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Sony Vaio
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Something like this: Amazon.com: eForCity SDHC / SD / MMC Memory Card Reader to USB 2.0 Adapter, Smoke: Computers & Accessories
Thanks for that :thumb: :dinesh:
    Sony Vaio
Where I come from SanDisk is the cheapest. And the thread starter is asking about music not movies video or HD.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Sandisk is among cheapest here too, I have two micro CD 16GB in the phones and another full size one of 4GB in a camera and all are still going strong for couple of years. Burnt couple of Kingstons though.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I have a 2-3year old 8GB SanDisk cruzer blade that has had atleast 9 persistent Linux distros which means lots of writes and formatting and it's still going strong. They're cheap and dependable like a Levi's jacket.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Thanks Cliff :) I also have PNY when I couldn't get SanDisk.
    Sony Vaio
