recording onto an SD card
  1. #11
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    Quote Originally Posted by adamf View Post
    Untrue. I bought the absolute cheapest USB 2 stick (3 for 8gb from Asda) so I could put movies on it to watch from my TV box. It couldn't provide the data fast enough. It would just freeze. I copied the exact same data to a slightly better quality SanDisk one and it was OK.
    Where I come from SanDisk is the cheapest. And the thread starter is asking about music not movies video or HD.
  2. #12
    Sandisk is among cheapest here too, I have two micro CD 16GB in the phones and another full size one of 4GB in a camera and all are still going strong for couple of years. Burnt couple of Kingstons though.
  3. #13
    Bamberg Germany
    I have a 2-3year old 8GB SanDisk cruzer blade that has had atleast 9 persistent Linux distros which means lots of writes and formatting and it's still going strong. They're cheap and dependable like a Levi's jacket.
  4. #14
    Quote Originally Posted by Cliff S View Post
    Thanks Cliff I also have PNY when I couldn't get SanDisk.
  5. #15
    Hi I've looked on Amazon uk and found a reader\writer which supports W8.
    Thanks for your help.
Page 2 of 2 FirstFirst 12
I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue. Things I've tried: The mic is not muted and the volume levels are maximized ...
Windows 8 When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone. But I want to record the sound directly from the sound card (or whatever it is). I know its possible, I have done...
Audio Recording Issues in Sound & Audio
I recently purchased a ASUS G750JX-DB71 laptop, and updated from 8 to 8.1 I am having one problem, most likely user error. When I record either audio such as yotube, or itunes radio with either Sound Recorder, or Audacity. the playback is very "tinny" (low level, poor quality, very...
help with screen recording in General Support
whenever i try to record my screen,whatever software and settings i use,when i play back the video it shows on the top half of my screen and the rest is just black,either on windows media player or on the movie maker. heres a screenshot of what im talking about: 30384
I run a triple monitor setup on windows 8 64bit. I was originally on windows 7 but decided to give 8 a try. What i typically do is run a game like world of warcraft on one monitor and then i am using camtasia on another monitor to record streaming video. In windows 7 this worked great because i...
Solved computer recording softwere in Software and Apps
ok i need some smart peoples help i wanna make some game videos for youtube but i aint got the softwere to record my computer does anyone know any good and cheep softwere i can buy from amazon or play.com
It also slows down my computer it appears - The driver that was installed automatically says 2006 IC USB Storage-CFC USB Device this is the hardware ID under USB MASS STORAGE DEVICE USB\VID_1019&PID_0C55&REV_0100 USB\VID_1019&PID_0C55 And under one of the Tabs:...
