Realtek audio not working after win 8.1 pro
  1. #11
    United States
    Windows 8.1 Pro 64-bit
    Could try Driver Sweeper as a last resort, it has an option for Realtek driver cleaning: Guru3D - Driver Sweeper
    Actually it is DDU now and doesn't have Realtek cleaning anymore. I used it in the past and fixed a problem for me. Oh well.
  2. #12
    win 8.1 pro N
    would updating the bios do anything? i noticed i'm running version 2.5 but the MSI website has version 2.8 available?
  3. #13
    United States
    A lot of times BIOS updates are for new CPUs. Is there a changelog that says what the newer one does?
  4. #14
    United States
    Visited the MSI site. These are the drivers you are installing?
  5. #15
    win 8.1 pro N
    for the 2.8 update this is all it has
    - Improved Memory compatibility.
    - Update microcode
    but for the 2.6 version i have noticed there is something about improved audio problem when using IVY-bridge cpu,
    - Add more DMI information.
    - Improved audio problem when using IVY-Bridge CPU.
    i have the intel I7 4930K processor, but not sure if its IVY-bridge or not
  6. #16
    win 8.1 pro N
    yes that is one of the drivers i've tried but that particular one comes up with an error message saying no driver was supported in the package
  7. #17
    United States
    Something is not right. Is their support any good? May need to contact them or check their forum. Sorry, all I have left.
Page 2 of 2 FirstFirst 12
Hello, I recently got a set of 2.1 HiVi Swan M-10 speakers and hooked them up to my laptop until I can finish my build. When I first hooked them into my E55-A Toshiba Satellite the bass wasnt coming from the sub in fact it was combining into my L/R speakers making them sound terrible. A quick...
I bought a Gateway E56R41u to replace my Acer netbook. I'm really happy with this machine. However, I downloaded the free upgrade to Windows 8.1 and my audio quit working. I've downloaded all the drivers that I could find and nothing works. Is there a driver for another machine that will work...
I have already tried a lot of different drivers, including the one provided by the asus website (For win 7) and the other provided by the realtek website, but i still have the error that no audio devices are installed. Any help? Thanks in advance
