Using iphone headphones and turtle beach headset with ASUS
    I'm using an Asus 2 in 1 flipbook or whatever it's called.
    It only has one port for an auxiliary input for headphones/mic (on my laptop it's labeled as a mic port). I can't use my iphone headphones to speak with and I can't use my turtle beach x12s because I need both headphone and mic inputs (along with the usb port).
    Is there an adapter out there I can use? If so, which one is the right one?
    What is the exact model number? I can't research what you need without that.
    The model is Q502LA-BBI5T12
    bump
    I can't find the specific specs for that unit. Without that I can't say why or how the jack works. Sorry.,
    I just looked up another model ASUS and the combination jack in those can be either a microphone OR a headphone, but not both. If you want both you will have to use a USB connected headset/mic unit.
Hello all. Unfortunately I have an issue that has been causing me much frustration over the past few days. Here's the deal, I have a pair of headphones, with a microphone, and a headset that I use for my PS4, both with 3.5mm jacks, that I want to use as a microphone for my laptop, as opposed...
Turtle(s) in Chillout Room
2796827969
Just bought a pair of Turtle beach ear force Z2 today at walmart it has the pink and green connectors for headphones and microphone. The headphones work great except the microphone doesn't work. When I plug in the pink microphone cord the windows does it's default noise acknowledging that I pluged...
As the title state I'm having trouble with getting my Turtle Beach sound card to work. I've tried running the driver installer under compatibility mode for both 7 and XP but both fail at finding the actual card. I know this is a fairly older card and probably doesn't have much support behind...
Hey guys and girls, just got this windows 8 preview up and running and all is well bar one thing. It seems i have been able to get my sound working through HDMI and a direct sound plug from my keyboard. However, when i attempt to use the headphones (earforce charlie, limited edition, turtle beach)...
Random Turtle! in Chillout Room
from the other day https://www.facebook.com/photo.php?v=208875892509080
