Laptop microphone making static noise.
    Hello, recently I was having some issues with my sound on my computer (I could not open my volume mixer) so I was given the advice to run a "sfc/scannow" in CMD. The scan fixed that issue, along with generally making my computer faster (I suspect I had some issues with my hard drive aswell).
    The only problem is that now my friends on skype tell me that there is a very unpleasant static sound coming from my mic and that I sound low and muffled. I am using the mic that is built in my laptopt, I have an MSI GT60 laptop.
    I have tried uninstalling the microphone using the device manager and then restarting the computer, but that did not work.
    Help is very appreciated.
    I went into "handle audiounits" (roughly translated) in the contorl panel, there I went into recording and then I selected my mic. From there I could select a couple of different modes in different frequencies. I chose one called "Channel 2, 24bit, 96000 Hz (Studioquality)" and now the static is much less noticable, but still there.
    I have also tried reinstalling my chipset driver now, did not work.
    Norway
    Windows 8.1 Pro x64
    You can try to install Realtek HD Audio Manager and turn on in the control panel at the microphone tab the two options to reduce background noise. Thats how i fixed it atleast.
    Yeah I've seen that advice floating around in a couple of other threads, but I don't have it on my computer, and I can't find anywhere to download it. As I said I've tried reinstalling my realtek driver earlier, shouldn't the Realtek audio manager have been reinstalled simultaneously?
    Would appreciate a link to where one can download it.
    I think the problem is fixed now, the strangest thing happened. I installed a previous version of the realtek audio driver and now I have a completely different set of options to choose from when selecting the microphone in the audio device manager and the static seems to be gone aswell. It is very mysterious but I guess I am marking this thread as solved.
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
I have an hp laptop that i used to use to play games on using my razer kraken pro headset and mic and headphone components work just fine the computers microphone set up can hear me clearly and everything is fine. Although when I go to use it on my computer which I bought for myself for xmas it...
Bad noise on quite new laptop. in Drivers & Hardware
Hi, I hope somebody can give me an opinion from his experience. This laptop is 4 months old, Asus X501A. I had to return another one to Amazon because it made some bad clicking noises and the hard disk was faulty as Hard Disk Sentinel said it was with 68% health new. So, this laptop model might...
I just got myself a brand new PC with Windows 8. My problem is getting my mic to work the same way it did with my laptop with windows 7 64 bit (Worked perfectly, microphone level at 47 and boost at 10db). I've tried everything, and even with microphone level at 100 and boost to 30db its just...
I have an HP 2000-2b10CA and I bought it FIVE DAYS AGO!! I was checking if everything worked so I shot a video and when I played it back I heard nothing! Then I found out it was my mic! I searched online and a lot of people told me to go to the settings and set it as my default device but IT...
I have the asus s400ca it has the microphone and headphone in the same jack. My headphones are fine in any other laptop but when I plug them into my new asus I hear very loud static even when playing music. It came with via hd audio and I can specify any other information if necessary, please...
Hi everyone, I hope i'm posting in the right place. I joined this forum because i need some help. Less then a week ago i purchased a new sony laptop model number sve151a11w. My problem is almost every time i play a game (i only have dawn of war 2 + expansions and minecraft at the moment) after a...
