Windows Sound Control Panel won't open
    Norway
    So I've detected that my PC has been a bit slow lately, it takes longer to load webages and stuff. But this strange thing happened. I was rendering a youtube video, when Sony Vegas Pro 12 was done with the file, the software crashed, and after that my PC has been complete sh*t. Before I restarted it I couldn't even watch youtube videos, they rendered but wouldn't play. Spotify crashed and I had to audio.
    I restarted my PC and then everything seemed nice, but then when I was about to launch TheHunter:Primal I had to switch over to my headset, and for some reason I couldn't open Windows sound panel. So atm I can't open sound panel. I really don't know what happened. I need help asap.
    I've received help on this forum before, just on another account and I've never been as satisfied. I really hope I can feel the same way this time too
    Norway
    Solved
    Well, I solved the audio problem on my own. All I had to do was to disconnect my PC from internet, delete all the audio drivers from Device Manager and I downloaded this: https://drive.google.com/file/d/0B53...ew?usp=sharing
    I restarted my PC and then I installed the package which I downloaded. I restarted my PC again, and Voila So if someone has the same problem as me using Asus Maximus Hero VII Z97 Motherboard, maybe you also can benefit from this.
Hi, I am hoping someone can help, I upgraded to 8.1 last night and all was ok until I started my PC this morning. The PC boots up and I can log in ok but I am unable to open any browsers, use the start bar or actually get in to most programs, use the search function or get in to any settings...
How to Add or Remove Control Panel in This PC in Windows 8 and 8.1 This tutorial will show you how to add or remove the Control Panel folder in Computer (Windows 8) or This PC (Windows 8.1) in File Explorer for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. You must be...
There is a weird thing in my control panel called Akami Netsession interface control panel, how can I remove it? It says Application not found when I click it. Screenshots: Screenshot by Lightshot Screenshot by Lightshot
Is there a way to make a shortcut to open or go to a specific item in the CP? I'd like to be able to do this with a few of my most-used, such as Color and Appearance, for changing taskbar and windows borders colors. I have a macro program that will do it, just wondered if there were direct links to...
How to Open the Control Panel in Windows 8 and 8.1 In Windows 8.1 and Windows RT 8.1, there are a few different ways to find and change your settings: PC settings, Control Panel, the Settings charm, and Search. Most of the settings that you'll want to change can be found in PC settings. In...
is there a solution for this coz i really like it at first glance coz its a full screen control panel and i like that metro style
Solved Windows 8 Metro Control Panel in General Support
My control panel icon on Metro start screen was lost!! I could not use "Change user tile"! How to restore control panel,please help me!
