Only left earbud works when inside audio jack
    I just got my new laptop with Windows 8.1 a few days ago and everything worked fine until now. When I plug in my earbuds, only the left earbud works. I've tried nearly everything I found online but to no avail. I've tried reinstalling the Realtek HD Audio drivers and system restoring to the earliest point, but nothing works. Any ideas?
    Also the speakers seem to work correctly, its just when I have earbuds in.
    In the properties a lot of time there is a balance setting in the sound menu somewhere, maybe it got changed? Maybe the headphone port is bad? If there is dust or something in it that is blocking the top, maybe bottom ring (one ring is right headphone one is left I can't remember which is which) from making contact.
    You were referring to the laptops speakers and not external ones correct?
    Quote Originally Posted by bboes13 View Post
    i tried dislodging any dust but there wasn't any.
    And while looking at the Sound menu, are my headphones supposed to show up in the playback/recording menu? All I see is speakers, realtek digital output, microphone, and line in (which is showing it is not plugged in)
    And yes, I mean the laptop speakers.
    If your ear buds are 4 zone, like this:
    and your laptop is like this:
    you should be OK,
    however,if your laptop is like this:
    then you need one of these:
    Quote Originally Posted by Edwin View Post
    you should be OK,
    yes, my earbuds look like the first image and my audio jack looks like the second image but its just a picture of headphones, not with the mic in it. But when I first got my laptop it was fine, so I assume I have the right things, it just stopped working correctly today.
    Hmmm..., can you get your hands on another pair of regular headphones you could try out?
    I tried it with a pair of Apple ear buds, no luck. It works perfectly fine when I plug it in my iPhone, just not in the computer.
    I'm thinkin that female input is only 3 zone or there's something jiggered in it.
    It's just so strange because one day it was working perfectly with the same ear buds and such, and one day its just isn't working correctly. Is it possible there is a setting I accidentally switched off or something?
    Could be dirty.
    Try a Q-Tip lightly dampened with rubbing alcohol.
    Go nice and easy though, and feel for snags, you don't want to leave any cotton in there. Give it a minute or two for the alcohol to evaporate.
    EDIT: You've gotta trim the Q-Tip a bit to fit. Wind the cotton on the stick tight and turn the stick going in and out the same way the cotton is wound so you don't unravel the cotton while inside.
Page 1 of 4 123 ... LastLast
I recently installed Win 8 Enterprise 90 days trial using Virtualbox. I tried Ctrl+Shift+Esc to bring up the task manager, but it apparently works on only the left ctrl and left shift keys.. Is this a bug or intentional ? Update: Omg, fatal typo. I meant Ctrl+Shift+Esc. Sorry.
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
I have been working on this problem for two days now. I decided i need help. I have set up the desktop the way i want it with fonts and icons I can see. Even got my firefox set up. My problem is when i open any folder the font is so thin and small i can not read it. i did do the screen resolution...
Hey everyone! I recently got a new computer, an Asus Zenbook UX302lg, and let's just say it's been a whirl of problems. I've solved most of the original issues, but one's now popped up and it's been bugging me for a few hours! My windows store DOES open without hiccup. However, once it's...
Hello I have a audio jack cable i.e. http://shop.rabtron.co.za/catalog/images/3.5mm-jack-lead-male-to-male-stereo.jpg and I want to listen to music on phone through computer speakers. It works, but..... In the sound control panel settings>recording tab>line in properties>Listen tab,...
I have searched everywhere for an answer to this... I have the latest Realtek HD Audio drivers installed (2.70) on a Windows 8 Pro PC. I have all other Audio devices disabled and the audio works great with every program/app I have (XBMC, MS Media Center, Music App, Internet Explorer, etc.). ...
