Only left earbud works when inside audio jack
  1. #31
    Quote Originally Posted by catssss View Post
    Quote Originally Posted by bboes13 View Post
    If you'd like, but if it looks like metal at the bottom you're all set.
    I couldn't get a clear picture, but i can see metal at the bottom and nothing seems to be messed up.
    I figured that wouldn't be the problems but I'm sure it does happen.
    How old is the laptop? Do you have a set of computer speakers or any other speakers (not headphones) that you could plug in to it? Maybe the sound card/motherboard is just broken..
    Edit: you said it is only a few days old, maybe see if another set of external computer speakers or using the port as an auxiliary port for a stereo or something if it works, maybe using headphones with a mic acts screwy in the port? Although I've never had that be an issue.
    If it's only a couple of days old call the laptop manufacturer, that never hurts.
  2. #32
    Yeah, that's what I'm gonna do, thank you for your time!
  3. #33
    Not a problem! Let us know what they say/do/if they can fix it.
  4. #34
    This may sound dumb but did you plug them in all the way?
  5. #35
    Quote Originally Posted by MCPlayer18 View Post
    You know...such an obvious question and easy to assume he did, but one that shouldn't be overlooked at the same time.
  6. #36
    I didn't contact my manufacturer yet but I think I will now because I did a full wipe on my computer and reinstalled all of the drivers and still no help, so I assume it's a hardware problem.
  7. #37
    Yeah that's odd. Just make sure they at plugged in all the way, literally the only thing I didn't think to try. But it does sound like a possible hardware defect.
Page 4 of 4 FirstFirst ... 234
I recently installed Win 8 Enterprise 90 days trial using Virtualbox. I tried Ctrl+Shift+Esc to bring up the task manager, but it apparently works on only the left ctrl and left shift keys.. Is this a bug or intentional ? Update: Omg, fatal typo. I meant Ctrl+Shift+Esc. Sorry.
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
I have been working on this problem for two days now. I decided i need help. I have set up the desktop the way i want it with fonts and icons I can see. Even got my firefox set up. My problem is when i open any folder the font is so thin and small i can not read it. i did do the screen resolution...
Hey everyone! I recently got a new computer, an Asus Zenbook UX302lg, and let's just say it's been a whirl of problems. I've solved most of the original issues, but one's now popped up and it's been bugging me for a few hours! My windows store DOES open without hiccup. However, once it's...
Hello I have a audio jack cable i.e. http://shop.rabtron.co.za/catalog/images/3.5mm-jack-lead-male-to-male-stereo.jpg and I want to listen to music on phone through computer speakers. It works, but..... In the sound control panel settings>recording tab>line in properties>Listen tab,...
I have searched everywhere for an answer to this... I have the latest Realtek HD Audio drivers installed (2.70) on a Windows 8 Pro PC. I have all other Audio devices disabled and the audio works great with every program/app I have (XBMC, MS Media Center, Music App, Internet Explorer, etc.). ...
