Only left earbud works when inside audio jack
  1. #21
    Maybe, there is a windows update that you haven't installed that addresses this problem (or caused it I imagine)? I really doubt you have any, Windows 8 has been way better about installing updates than windows 7 was.
  2. #22
    Quote Originally Posted by bboes13 View Post
    Maybe, there is a windows update that you haven't installed that addresses this problem (or caused it I imagine)? I really doubt you ahve any, Windows 8 has been way better about installing updates than windows 7 was.
    Tried reinstalling the driver, didn't work, and there's no available updates. :/
  3. #23
    Did you only remove it, then reboot? Don't reinstall or anything until then (obviously you can just place the driver .exe on the desktop so if it doesn't work out you can update it/reinstallit), just remove and reboot.
  4. #24
    Yeah, I uninstalled, booted, installed, and booted again.
    Edit: Is Realtek High Defintion Audio is the right driver? Because that's the one I reinstalled.
  5. #25
    Did you test your speakers between uninstalling and booting before reinstalling it?
    And yeah it probably is...I honestly haven't dealt with a PC that doesn't use Realtek, not saying there isn't one, but Realtek is real popular. Realtek's website is pretty trash if you ask me though..
  6. #26
    Yeah, I have a driver installation CD that came with my computer so I didn't have to use the site. And I did notice the speakers seemed a bit louder when I reinstalled it, but it could have been my imagination haha.
  7. #27
    Well the tip is the left audio device, use a light shine it down into the slot, if there is anything down there then it could cause the tip to not get good enough contact to give you sound. Common issue with iPod's from being in pockets they get lint smashed at the bottom...I guess maybe something got jammed in there on accident...I'm taking shot's in the dark now. Hahah, I say you should have an (angry) call to the manufacturer of the PC.
  8. #28
    I looked inside with a light and I don't really see anything wrong with it. But what do I know? Haha, would it help if I took a picture?
  9. #29
    If you'd like, but if it looks like metal at the bottom you're all set.
  10. #30
    I couldn't get a clear picture, but i can see metal at the bottom and nothing seems to be messed up.
Page 3 of 4 FirstFirst 1234 LastLast
I recently installed Win 8 Enterprise 90 days trial using Virtualbox. I tried Ctrl+Shift+Esc to bring up the task manager, but it apparently works on only the left ctrl and left shift keys.. Is this a bug or intentional ? Update: Omg, fatal typo. I meant Ctrl+Shift+Esc. Sorry.
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
I have been working on this problem for two days now. I decided i need help. I have set up the desktop the way i want it with fonts and icons I can see. Even got my firefox set up. My problem is when i open any folder the font is so thin and small i can not read it. i did do the screen resolution...
Hey everyone! I recently got a new computer, an Asus Zenbook UX302lg, and let's just say it's been a whirl of problems. I've solved most of the original issues, but one's now popped up and it's been bugging me for a few hours! My windows store DOES open without hiccup. However, once it's...
Hello I have a audio jack cable i.e. http://shop.rabtron.co.za/catalog/images/3.5mm-jack-lead-male-to-male-stereo.jpg and I want to listen to music on phone through computer speakers. It works, but..... In the sound control panel settings>recording tab>line in properties>Listen tab,...
I have searched everywhere for an answer to this... I have the latest Realtek HD Audio drivers installed (2.70) on a Windows 8 Pro PC. I have all other Audio devices disabled and the audio works great with every program/app I have (XBMC, MS Media Center, Music App, Internet Explorer, etc.). ...
