Only left earbud works when inside audio jack
  1. #11
    Quote Originally Posted by Edwin View Post
    Could be dirty.
    Try a Q-Tip lightly dampened with rubbing alcohol.
    Go nice and easy though, and feel for snags, you don't want to leave any cotton in there. Give it a minute or two for the alcohol to evaporate.
    EDIT: You've gotta trim the Q-Tip a bit to fit. Wind the cotton on the stick tight and turn the stick going in and out the same way the cotton is wound so you don't unravel the cotton while inside.
    Nope, didn't work :/
    Edit: Tried again, still nothing.
  2. #12
    I've never needed a mic and headphone plug adapter, that's typically what you'd use to use like apple headphones with a mic to use the mic and headphones at the same time I believe. 2, 3, or 4 ringed headphones should work in the headphone port as the bottom two rings should always be the left and right headphone contacts. So I imagine maybe the rings are dirty or broken on the inside.
    With your headphones plugged in see if you can find anything with a balance option (usually by clicking on the little orange speaker thing that pops up when you plug in the headphones) and see if maybe the balance is set to one speaker or something.
  3. #13
    Quote Originally Posted by bboes13 View Post
    Gyazo - 7ed4328f5aa04358e372a919d14066bb.png is this the right menu to find the balance options?
  4. #14
    Yeah that looks right! I believe there is a balance setting in there, and if you have something in the headphone port it should allow you to adjust it. I use my aux port on my stereo to go to my laptop, one speaker is closer to me in my room so I set more balance toward the farther one to make it sound even. I believe that menu will do the trick. I was helping you from work so I wasn't able to go search for the menu till now.
  5. #15
    It's no problem, thanks for guiding me there, but I'm only seeing Speakers, Digital Output, and Microphone. No headphones or anything. Could that be part of the problem of why my headphones aren't working?
  6. #16
    After taking a second glance now that I'm home, if your speakers are okay then I'm guessing the balance isn't off as winodws just makes sure it is playing through speakers. So you can right click the white speaker icon and press playback devices. Then click speakers then down at the bottom the properties box will ungray click that, make sure it says the 3.5mm jack is hooked up. You may also check the balance settings by pressing the levels tab then balance.
    I would personally try to remove the drivers, reboot the system, and it should install it's own drivers, then try again.
  7. #17
    Quote Originally Posted by catssss View Post
    No, the headphones are placed under the speakers section, as they are just external speakers so the laptop and sound driver handles them the same.
  8. #18
  9. #19
    Ok, this is what I came up with: Gyazo - 05f476683af1e3cb448e0e963dc888e4.png Gyazo - 46864783d0c24ced65c7e22d362c45c4.png
  10. #20
    Try looking into the balance option right there in your second photo, although after reading and looking at it when I got home I am in disbelief that it would be the issue now, but doesn't' hurt to check I imagine. But I would delete the driver and reboot the system, that helped me when I had problems with my Nvidia drivers, removed them, rebooted, for some reason problem solved updated the drivers again and everything was okay, blew my mind but it worked. Haha
Page 2 of 4 FirstFirst 1234 LastLast
I recently installed Win 8 Enterprise 90 days trial using Virtualbox. I tried Ctrl+Shift+Esc to bring up the task manager, but it apparently works on only the left ctrl and left shift keys.. Is this a bug or intentional ? Update: Omg, fatal typo. I meant Ctrl+Shift+Esc. Sorry.
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
I have been working on this problem for two days now. I decided i need help. I have set up the desktop the way i want it with fonts and icons I can see. Even got my firefox set up. My problem is when i open any folder the font is so thin and small i can not read it. i did do the screen resolution...
Hey everyone! I recently got a new computer, an Asus Zenbook UX302lg, and let's just say it's been a whirl of problems. I've solved most of the original issues, but one's now popped up and it's been bugging me for a few hours! My windows store DOES open without hiccup. However, once it's...
Hello I have a audio jack cable i.e. http://shop.rabtron.co.za/catalog/images/3.5mm-jack-lead-male-to-male-stereo.jpg and I want to listen to music on phone through computer speakers. It works, but..... In the sound control panel settings>recording tab>line in properties>Listen tab,...
I have searched everywhere for an answer to this... I have the latest Realtek HD Audio drivers installed (2.70) on a Windows 8 Pro PC. I have all other Audio devices disabled and the audio works great with every program/app I have (XBMC, MS Media Center, Music App, Internet Explorer, etc.). ...
