Asus MX279H Monitor and Soundcard Trouble
    Hi all,
    My soundcard is an ASUS D2X
    My Monitor is an Asus MX279H
    My problem is I can't get the monitor to route the sound to just my soundcard and take advantage of using 4 speakers. I've tried using a 3.5 plug from monitor to soundcard with no joy.
    The only way I can use the monitor speakers is if I select MX279-C as default but then obviously I can't use my soundcard or creative speakers.
    I've attached a screenshot of my sound options.
    Many Thanks
    Windows will only allow one "default audio playback device".
    I don't understand exactly what you want or want to do.
    Before I brought this new monitor I was using my creative speakers together with my monitor speakers through my soundcard. So in essence I want a 'line in' to be my creative speakers and the 'surround sound' plug to be my monitor speakers.
    Now I'm using a HDMI cable with this new monitor I cannot combine both sets of speakers to work together with my soundcard. As the HDMI cable obviously plugs into my NVidia card, where as before on my old monitor it was a 3.5 mm plug to my soundcard.
    Could the OS or the Graphics card be choosing the HDMI as first preference over the 3.5 plug for sound? I've been trying the 3.5 mm plug in my new monitor but I cannot get it to work.
    I'm running out of ideas?
    As I mentioned you can only have one audio playback device, either the HDMI audio or the "Speakers" (PC Sound card). But, you can't have both and the reason running a cable from the monitor to the sound card does nothing.
    Ok that's disappointing. Ok thanks for the advice.
What is the root problem I'm having and a workable solution for connecting a 3rd monitor to a Win 8.1 Pro x64 desktop? My primary desktop has a ATI Radeon HD 46000 Series display adapter with 1 gb or onboard dedicated video memory. I have a HP w2338h LCD monitor (1920x1080) as my primary on...
I'm trying to use an external Samsung TV/monitor (model LN-T2642H) through HDMI. The native resolution of the monitor/TV is 1360X768, which is also the native resolution of ASUS T100. If I try to use the monitor/TV as the only display, the device selected is Generic PnP Monitor and the native...
Hi, I have 3 monitors, BenQ RL2450, two of them via DVI and one via HDMI. Issue, HDMI connected monitor goes black every now and then. Not really a pattern in it. Sometimes it can flicker black once every 5 min, sometimes once every 30 minutes. Monitors are ok, checked with other computers,...
I recently broke the screen to my asus n56vz. I ended up removing the whole top panel and removing the inverter cord. I plugged in a external monitor and it worked fine at first. When i restarted i noticed that it starting running hotter and displayed a second option on a 768p monitor. My 1080...
ASUS PQ321QE Hi res monitor in Graphic Cards
Hi there Don't get jealous - but I'm thinking of taking delivery of one of these. I always buy MYSELF an XMAS present too !!! - yes that time of year coming up. Just wondering if any decent Video cards can support video at this resolution (4K - 3840 X 2160 ). While it's "only" a 32 inch...
Asus Monitor VK278 in Graphic Cards
Hi. Recently bought this monitor ASUS - Display- VK278Q Connected it with the HDMI from my ATI Radeon HD 5770 Im using Windows 8 Pro 64 Bit I assumed windows would adjust or install whatever drivers needed to get full output from the monitor. Nope.
Windows 8 Monitor trouble in General Support
So, my computer was working fine. I leave my room to get something, come back and my cat is on my keyboard. I shoo her away and try to wake my computer up but when I get my monitor to turn back on, all I get is the monitor's test pattern. I've disconnected and turned everything off and then...
