Playing Sound via HDMI When Monitor Is Off
    Very helpful forum so thanks in advance for addressing this -
    I have an Asus laptop running Intel Display Audio and I have it connected to an external monitor via HDMI. I also have external logitech speakers, which for whatever reason, sound a lot better when plugged in to the monitor than the headphone jack of the laptop (which has a much muddier sound). I want to be able to play music when the monitor is off/sleep, however when I do that, obviously the sound turns off. The settings on the monitor were pretty basic and didn't see anything to change it. Is there any workaround?
    Joisey
    Windows 8.1 consumer 64 bit
    You could get an hdmi switch that separates out the audio. The one linked below is a example, there are cheaper alternatives too.
    Amazon.com: Monoprice 4x1 HDMI Switch w/ TOSlink & Digital Coaxial Audio Output (Audio Return Channel/3D/CEC Support): Electronics
    Win 8.1 Pro 64bit
    Quote Originally Posted by mikeytg View Post
    Idea is good, but the linked splitter outputs only digital audio. Unless your speakers accept it (most probably not, if it's not some kind of home entertainment system) you need to feed analog audio signal to it.
    This would be better (and way cheaper): HDV-M610 HDMI to AV Video Audio Converter - White - Free Shipping - DealExtreme - but you'd need to unplug the monitor to use it (unless the monitor has HDMI passthrough or the computer has more HDMI outputs).
    Or you can buy a splitter with analog audio output (most expensive, but neatest /hassle-free/ option): HDMI Splitter / Digital Audio Converter / Analog Audio Decoder - Black + Yellow (1-In / 2-Out) - Free Shipping - DealExtreme
    Easiest, if you have a separate digital audio output (coaxial or optical), would be to buy this: Cheap Digital to Analog Audio Converter
    With all these you'd need also a cinches to 3.5 jack adapter if you didn't get it together with the speakers (my old Logitech 2.1 speakers provided it): 3.5mm Audio Jack (Female) to RCA Audio Converter (30cm) - Free Shipping - DealExtreme
    Thanks. Yeah, unfortunately, I only have 1 HDMI port on my laptop and as noted, I have no coaxial on the monitor. The only out port I have for audio is for earphones. It sounds to me like the best solution might be the splitter w the 1-In,2-Out since I'd rather not swap in and out the monitor on my HDMI port.
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Solved HDMI No sound in Sound & Audio
Hi, for the first time ever I'm trying to connect my laptop to my TV via a HDMI cable, everything works fine apart from the sound, it's being played via the laptop for some reason. I went on the sound options on device manager, the "Digital Audio (HDMI)" option says "not plugged in" therefore I...
As the title says, I've tried connecting my TV to my computer with an HDMI cable, and the video part works, but no sound plays. When I checked the list of playback devices, the TV appeared (as shown below), but it apparently cannot play sound. 39269 I don't think I know anything beyond what I've...
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
monitor and HDMI in Graphic Cards
Hi, I connected my Fujitsu laptop to the "dining room" Tv (Its a cheap technika from Tesco 22") via HDMI cable, with immediate results. I then tried to connect the laptop to my new monitor Asus VE228HR 21.5". This is my main monitor connected to my desktop PC via VGA with a dual connection to...
No sound with w8 and HDMI in Sound & Audio
Hi there, I have recently acquired a gaming PC which has been built up from scratch by a local in my area who has good reputation for reliability etc. Most things are working fine, however I cannot seem to get the sound working through my television, which is my main (and only) monitor. The...
