Locking the microphone volume
    Hello!
    I have a Blue Snowball microphone which is a great mic, but and as you might know, it sounds like a vulcano errupting next to an exploding nuclear power plant if you have it set to 100% volume. That's why I have it at 60% and later boost the recordings in editing programs. The thing is that Windows randomly (usually every 5-15 minutes) decides to reset it to 100%, which is extremely annoying. I have done EVERYTHING I could to prevent it, but it's still happening. So I gave up on hope and am willing to have to run an utillity program in the background to keep it down. Anyway, the simplest way to do it is to have a program that every [x] seconds sets the mic volume to [y]%. Does anyone know where can I download such a program/script? Last time I tried to download one, it needed like 3 seperate programs and addons and I don't even know anymore. Is it really THAT hard?
    thank you
    Windows should not be resetting it. I suspect some other program is what is causing it. Skype is one potential program. Check what you have running when you record.
    I have unchecked "Let other programs take control of this device" (I have windows in Slovenian so I don't know exactly how the option is called in the English version) in my mic's settings, also I'm only running Skype (in which I also unchecked the option that lets it control the mic) around 50% of the times when I record. I checked many programs that I frequently use and none seem to be the cause. It just randomly decides to change it. I know that Windows can't be responsible but no other programs seem to be either. I'll keep on checking all the programs. When I record I'm usually running: the game I'm recording, Windows vanilla microphone recorder, Nvidia Experience, sometimes Skype (doesn't have the permission to control my mic) and Mozilla for Facebook and Twitter. It also happens when I stream, but for that I run OBS, the game and Mozilla. I'm really confused o_O
    I have a recording studio, but that is using Sonar X3 with separate recording interface unit, not a USB microphone.
    Try recording with the free Audacity and see if you have the same problem with that.
    Considering what you have running or use, any of those could be suspect.
I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue. Things I've tried: The mic is not muted and the volume levels are maximized ...
User Locking in User Accounts and Family Safety
Hello all, I need help getting Windows 8 to work in my business environment. The issue I am having is users can lock the computer and there is no way to over ride and log in as an administrator. What would be the best way to accomplish this in 8? I currently have it set to require a username...
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Microphone volume very low in Sound & Audio
Hi. Before I start, yes, I have searched the forum for this issue before. I've done possibly everything everyone has said and still no fix. I've read that you have to go to Communications in the Sound window, and select Do nothing. That doesn't work. 23415 I've read that you have to go to...
Locking tiles? in General Support
I wonder if there is a way to prevent tiles from dragging on the start screen? Hard to believe MS left this out! I often drag or swipe across the start screen and move a tile wo/ intending to. This happens often on the touch screen of my Samsung slate. Not sure if it happens as easily with a...
hey there guys. well as you can tell, i think chrome is making my system lock up periodically. its not just chrome that locks up either but the entire OS. at first i thought it was Pokki, my start menu replacement but even after a completely clean install of the OS it is still happening and the...
