Device sound, constanly bleeping
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    If it's a desktop PC power down and unplug your PC from the wall plug so it can't power up by accident. Take precautions against static discharge for the following. Touch metal first and don't do this on a carpeted area if you can help it. Do it on a table or wood floor. Now open the case and reseat all your add-in cards. If you don't want to actually remove them and reinstall them just press them down firmly to make sure they are fully seated in their slots. Then double check all your data and power cables to make sure they are firmly connected. Also check any cables for front panel USB ports or card readers etc. Once your satisfied that nothing has come loos, put the cover back on and check all the external cables. Then power back up and cross your fingers.
    Could be few other things too if it's none of HW. Network (wired, WiFi or BT) turning off and on. Video switching from IGP to video card or other way around. Power saving options turning on and off on any device.
    It bleeps for about 20mins or so then stops this is when my PC is booted up.
    Should I still check my power supply etc?
    That's up to you. If it was me with that issue I would want to figure out what's doing it.
Hi, I have been having sound problems with the speakers on an HP Ultrabook. There are times when the laptop speakers stop working. When this occurs, I go to Control Panel>Sound, select the speakers(only one set to select), select Configure and Test. After selecting Test, I receive the message...
Hi all. In terms of gaming, hardware and things like that, I am pretty experienced. This one has me stumped. I have searched places I know that might have a fix, but found nothing helpful. I recently purchased a Plantronics Gamecom headset, and am really enjoying it, but there is one...
Whenever I'm in the Windows environment (meaning not doing anything in full-screen mode), the "Device Eject Sound" (the little do do do do that plays whenever you eject a device) will constantly play at almost random. Sometimes itll play three times in a row right after the other, sometimes it wont...
