No sound on start-up, Win8 needs time to output sound
    (Solved) Win8 needs time to output sound
    Title says it all. I need to wait at least five minutes to be able to hear anything on my laptop.. I can't hear songs nor play videos..
    Help would really be appreciated.
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    For start up sound go to personalize>sounds>at bottom of box place a check for "Play Windows Startup sound. With a laptop you probably are using realtek HD sound driver... you could look in task manager and see if it is turned on at startup, also in event viewer>windows logs>system and look at the time when you booted and see if there are any audio errors.
    Can't believe how easy the fix was, just checking an option.
    Thank you so much brother.
    Bamberg Germany
    You're welcome. I've noticed that a lot of the default system sounds are turned off by default in windows 8.1.
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Problem: My laptop with OS Windows 8 will become no sound frequently. I try to find out the cause, and discover that the device is being used by another application, but I can't find any application using it, here is the screenshot: 47290 47291 Under this situation, when I open Window Media...
Hi all, I was wondering if its possible to have a software switch which changes the in-use speakers. For example, I'm typing this sat at my desktop. The speakers are optimised for the person in this chair. Are there any media players (or other programs) which could switch the speakers over...
Onboard Sound: ALC 888s external DAC/amp: Fiio E17 Connection: ALC 888s out----Optical digital cable-----Fiio e17 SPDIF in I do not get sound when I set Realtek Digital Output (Optical) as my playback device. I tested the cable and fiio e17 on my PS3 and it works fine. I tried on windows 8.1...
Hello everyone,after using Windows 7 Ultimate on my laptop for almost 2 years I decided to upgrade to Windows 8. The first day it was working fine,no problems at all. The other day I disconnected my USB mouse and it would keep on playing the disconnect sound, however, I solved that issue. Recently...
HDMI Sound output issues in Sound & Audio
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
