Sound stops working Win8x64 CP.Build 8250 Toshiba Satellite L755-S5306
  1. #21
    I removed AVG as suggested. I removed it once in safe mode without the tool from avg. Sound dropped again, so I went back into safe mode and ran the tool just to be safe, and it just went out on me again.
  2. #22
    Quote Originally Posted by dugle80 View Post
    Cool. Complete the rest of my previous post and things should shape up.
    TVALZ_O.SYS is an important power management driver for Toshiba laptops. Old versions like the one you have now are a known issue under 7/8.
    If you can't find the specific driver for your model, it is part of the "Value Added Package" download. If downloading this to install it, you might have to use the device manager to install from its extracted directory. Also, check the device manager when done for the date of the driver to be newer - at least 2010 but newest is always best.
  3. #23
    I got TVALZ_O to a 2009 version, haven't found a 2010 or newer version yet. the QI is also at 2009. The TVALZ is from the value pack listed for my model on the toshiba drivers page.
    My sound still stopped working.
  4. #24
    Three things to recommend:
    1) Navigate to C:\Windows\System32\drivers and delete all files shown that start with "AVG" and reboot.
    2) If none were there or it didn't help, then create a new account on the machine with Administrator privileges. Use that and test how it goes there.
    3) Another way to test is to use the Task Manager to disable everything starting with Windows. Save then reboot and see how that is.
    Could also try disabling the Intel audio in the device manager, then reboot.
  5. #25
    Disabling everything in startup from task manager did not help, but using a different profile login did resolve the issue. I suppose I have my answer, now I just have to put my finger on it.
Page 3 of 3 FirstFirst 123
Hi all :) For some reason, neither my internal nor external DVD writers will burn DVDs. My internal DVD-RW is a tsstcorp cddvdw sn-208ab. Th external DVD-RW is a tsstcorp cddvdw se-208db. For a while I could burn a DVD by using "Fix it", but then I'd have to reboot, use "Fix it"...
Toshiba Satellite L875d-S7377 in General Support
Hiya this is my first post so if I screwed up I apologize in advance. I was recently given a Toshiba Satellite L875d-S7377 because my friend had bough themselves a new laptop and they didn't need this one anymore, me being without a laptop, they gave it to me. When I got the laptop, the touchpad...
Okay well this happened like 2-3 weeks ago, i have an extremely annoying problem.. The sound of my computer would randomly stop working for some reason.. Not only that, but when i watch youtube the video or any video it won't load and it would literally pause or freeze. To fix this i would have...
Hi In my new HP laptop, with fresh windows 8, sometimes when I'm using sound (eg. listening music in media player and using skype ou browser), sometimes the sound stops. Checking in event viewer, I found appcrash event logs. The sound drivers is updated and windows too. I downgraded the audio...
Anyone know if there's a way to reverse the "polarity" of the FN key on Toshiba Satellite C55D-A? All I can find is sticky key or notification settings. I'm looking to have F1 - F12 work like on desktop keyboards and hold down the FN key to adjust brightness, volume etc..
Anyone who can help me for the drivers to find it, please, , , :(
I recently purchased and updated my laptop to Windows 8 Pro. The touchpad works just fine but noticed gestures are not working. I did a Windows update, gestures still do not work. Weird how it's providing an older driver but I still tried it, doesn't work. I then went to Synaptics website and...
