'Unable to start the Dolby Audio Driver' - (Acer Aspire)
    Hi guys, I'm having an (what appears to be quite a common) issue with my sound since installing to Windows 8.1
    I have an Acer Aspire V3-571G laptop, and was recently asked to upgrade to Windows 8.1.
    Once I did that, a pop-up has come up saying:
    Dolby Home Theater
    Unable to start the Dolby audio driver. Please restart the computer or
    reinstall the driver if the problem persists.
    The audio for all my media players now refuse to work, while, say, Youtube appears to work fine.
    I've seen a few proposed solutions for this issue (including deleting, uninstalling and reinstalling of certain things), but most appear to be 'Lenovo' laptops. So basically I have a fear of deleting something wrong or doing some irreversible damage to my sound, since it may not be specific to my Acer Aspire.
    If anyone could give me a hand with how to solve this, that would be VERY much appreciated, as I am clearly not very tech savvy.
    Thanks guys and girls!
    United States
    Windows 8.1 Pro 64-bit
    Welcome to the forum!
    In your programs list you should have Acer Recovery Management. From there select Reinstall Drivers or Applications, then find Audio Codec and select.
    Thanks Popeye!
    I found the Acer Recovery Management folder, but couldn't find anything else you've said within it.
    I attached a printscreen so you can see what I mean. (they don't appear to be in any of those 'Helpfiles'.
    And also thanks for replying.
    United States
    No, you should find the program in your programs menu. Don't go to the folder. When you click on it should get something like this:
    Can try clicking on that Recovery UI executeable.
    United States
    Clicking on that eRecoveryUI executeable in the folder should work also.
    I did the first option you stated. It appeared to uninstall and install my Audio Codec (which was 'Realtek High Definition Audio).
    Now I have no volume button on my bottom right-hand corner, and when I check my 'volume mixer', it says 'no audio device is installed.'
    I'm assuming there's a very simple step I'm missing to kick-start everything?
    I went into Sound and clicked on the 'Properties' of my
    Speakers
    Default Device
    and there's a 'Dolby' tab - when I go to it, there's a pop up:
    ERROR
    Error opening registry keys. Please verify registry key permissions.
    Run RegDolby.bat from the driver folder to change.
    Would this be the next step?
    United States
    I would uninstall the audio device in Device Manager and select delete the driver if an option, run CCleaner (twice) on the registry. reboot and install the drivers from Acer Recovery.
    Did the laptop come with 8 or 8.1?
    The laptop came with Windows 8, and I was just asked to update to 8.1 the other day.
I updated to 8.1 because supposedly, it was to offer features similar to win 7. Instead, it's even worse than win 8. Now, the sound quality on my laptop is lousy because the Dolby Audio driver receives an error message and isn't working. I went to Lenovo (I have a Ideapad N Series 580) and...
I upgraded today to 8.1 and now when I start my computer I get a message box telling me <re-install Dolby advanced audio driver> I found the Dolby program in my control panel, programs and features, and there is no un-installer or, seemingly a way to re-install the driver. I don't want this box...
Acer aspire v5 low fps when unplugged in Performance & Maintenance
hi i have an acer aspire v5-473pg with windows 8 installe i5 and with nvidia geforce 740m my problem is as up some updates ( i really dont know if windows update or nvidia) changed my laptop performance. my laptop can play dota 2 around 50-60 fps plugged or unplugged. Its like saving power when...
I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I canīt open it, and when I try it says that I could re-install it. But how?
So many problems with this comuter it is even difficult to write this post. Anyone having problems with this laptop? Win8 works much better on my Samsung Ativ.
Hello. I have a problem. I go to the website NVIDIA and i make a download of the driver for windows 8 for my nvidia. the problem is when i install the screen turn off. Any ideias? Thanks
acer aspire resolution in Graphic Cards
here's a reg tweak to get resolution needed for win 8 on acer aspire. I do not know anymore than what is in the article. Windows 8 on Acer Aspire One Netbook - Screen Resolution etc... - Http Client Protocol Issues - Site Home - MSDN Blogs
