Background Noise in Skype.
    North Yorkshire
    Windows 8 Pro 64 bit
    Hi, I've used Skype for the most part without problem since it took over from Messenger.
    Following recent Skype updates the person I'm connected to receives a rapid repeated sound like a demented Woodpecker which stops while he speaks but starts again when he stops speaking. I can't hear this sound at my end; however if I use Skypes Call Test Sound I can hear this rapid dit dit dit when the sound test plays back to me.
    I've tried Skype Forums without success other than to discover that others are having similar problems since recent updates.
    In Device Manager I've tried ALL sound and recording settings which all state device working correctly. In addition I've checked Update Drivers and in all cases it states 'Latest driver installed'.
    This has prompted me to try Windows 8 Forum as the experienced members of which have provided many correct solutions.
    Thank you.
    Although your are hearing the "sound" issue, this is not really a PC sound issue but more an application issue. The "echo" could even be on a remote server somewhere. Regular landline telephone circuits even have "echo cancelling" hardware in them.
    As this has happened since a recent Skype update that is a good suspect and place to start. One of the other forum sections that are software oriented would also be a better place to post.
    North Yorkshire
    Thanks for your comments Fireberd, The problem is now resolved thank you. The person I mainly communicate with is my cousin and when visiting him yesterday we discussed the problem and having tried everything we could think of we felt that the latest Updates by both Skype & Windows 8.1.1 had made my old Logitech Web Camera obsolete/incompatible. Fortunately my cousin had a spare camera of later model and I installed it and all now working as it should be. This would seem to suggest that the problem was one that we perhaps too often encounter when updating the OS which leaves the hardware high and dry.
    I noticed that a number of people were complaining of much the same problem and they too may find they will need to get a new camera.
    Thank you.
    Thanks for the feedback and that you got it resolved. Strange that the hardware was the problem since it worked previously. Generally, that doesn't happen with application updates.
Solved strange noise from PC in Drivers & Hardware
About 2 days ago i opened PC case to do my regular maintenance of dusting inside. Usually use Compressed air. Have 2 case fans (1) 92mm (1) 80mm plus the CPU Cooler fan, my Graphics card has dual fans. Just other day and this only happens when i am booting the PC, i hear what sounds like and...
I have always used Skype for Desktop and only recently found that there is a Skype Modern App on my system. From what I have read it would seem the best plan would be to ditch the App and just continue with the desktop version. Have there been any recent changes that would make the the Modern App...
Hi, I occasionally play on my laprop in my front room with my family however when I'm on skype to my friends they can hear my TV and Family louder than I can! Is there any software that can lower the levels of background noise or any tips on how to make it so it's quieter for them?
Bad noise on quite new laptop. in Drivers & Hardware
Hi, I hope somebody can give me an opinion from his experience. This laptop is 4 months old, Asus X501A. I had to return another one to Amazon because it made some bad clicking noises and the hard disk was faulty as Hard Disk Sentinel said it was with 68% health new. So, this laptop model might...
I've experienced some problems and discomfort with skype for win8: - not able to show screen, - terrible design, - very slow response (i.e. when I click RMB, the menu shows up in several seconds, and I expect to see it immideately), - doesn't understand links to skype chat like...
so is there any differenced between thses two and I nedd both of them?
HDD locking noise? in Drivers & Hardware
I've recently just updated my BIOS on my asus laptop to fix my "ACPI.sys" problem but now, whenever I plug an external USB drive in, or do a hybrid shutdown my hard drive makes 2 loud-ish locking kinda noise (similar to when I turn on my laptop), i'm guessing its the HDD head parking... Should I be...
