Volume control has disappeared.
    Windows 8.1 64 bit
    First up I am a not a too computer smart 70yr old. For some unknown reason the volume control icon has disappeared from my task bar (when I move my mouse hard right and it shows battery state. internet access, language, volume etc.) which I use continuously. I have been to every avenue I can think of but am being informed this control has been de-activated and despite my efforts cant get it back.
    Can you please assist.
    San Jose - California
    Open the Control Panel, select "Notification Area Icons" and make sure you select to "Show icon and notifications" for Volume control
    To open control panel: Win+X then select control panel
    Windows 8.1 64 bit
    Thanks so much for your fast response. Have already checked this - it already shows as you advised. Tried changing to " Hide: and then changing back. When doing so I get a short message "This notification is not active" Does this assist in finding a solution?
    Windows 3.1 > Windows 10
    happened on my wife's laptop too..
    I think (if I remember right) I cleared the flash player cache and settings via control panel..
    I'm almost sure that's what did it..
    Windows 8.1 64 bit
    Not sure if you all got my vote of thanks so am posting this again.
    Thanks so much for your support
Im sorry upfront I don't know how to look up my specs. My volume randomly turns all the way down to zero on it own! on all devices (headest/speakers). It says all my drivers are up to date. I will reboot and the volume is restored back to 100%.Ive also checked communications tabs and the checkbox...
Solved Control panel has disappeared in General Support
Doing a general search is no longer bringing up the control panel. I have no idea how to find it otherwise?! Anyone know?
Make Volume Control On Top in Sound & Audio
I have a couple of speakers I use with my Desktop computer. On a previous set of speakers, the power button soon wore out, so with this current set, I have them on a power strip, and use that button. This solved that problem. I now see that the volume control on my speakers is becoming...
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
So I recently updated a Lenovo 540b all in one touch screen pc to windows eight. Everything worked perfectly. Today I played some music through the stock music app and this annoying on screen volume control popped up. Since then I have been unable to get rid of it without stopping the audio...
Volume Control in Sound & Audio
Hi Guys, anyone know if its possible to get an on screen volume control when you are playing music. At the moment I can only see how to start and stop music from playing. I can turn the volume up and down via my keyboard but would like to do it on screen via my mouse. If I drop to my old...
Previously I was able to pull up the on-screen media display when I press the volume button and previous/next tracks button on my keyboard but now the on-screen notification has disappeared and the volume control is not working. I am using logitech keyboard and I want to use the metro style...
