Windows Realtek Audio Popping Problems (Realtek ALC662)
    Hello all, I just got Windows 8.1 Pro as a gift from a friend and installed it just a few hours ago, and I noticed that I am having audio problems.
    Basically put, it's sort of random when this happens, but it seems to happen when sounds play rapidly, as letting a audio que play it's part will play with no popping nosies, here is an example of me showing this by using the sound that plays when you change audio:
    Vocaroo | Voice message
    The first 10 seconds are me playing the sound slow, with no popping. Then the sound starts popping when I change volume rapidly.
    I also checked DPC Latency Checker and everything is running smoothly:
    imgur: the simple image sharer
    I have all the latest drivers installed, and this happens with with no drivers. I just can't seem to figure out what the issue is here.
    EDIT: I forgot to mention that I've tried disabling drivers, removing the USB Keyboard and Mouse, as well as setting the audio to CD Quality.
    Thanks in Advance to the person who could help me with this.
    N.Y.
    Windows 10 Pro 64bit
    What type of speaker system are you using ? Monitor with HDMI, check video card settings ? Could be conflicting driver, possibly Video card. Also mattering to speakers used, check for loose connections, something could be disturbing speakers.
    Lots of reasons for popping and stuttering. Integrated card or PCI Slot Card?
    N.Y.
    I'm using a Stereo system, and I've already checked my video settings as I am using a Monitor with HDMI (I stated that I tried disabling drivers earlier.)
    The audio is integrated and I have not found any loose connection.
    N.Y.
    Quote Originally Posted by jds63 View Post
    Look at this ? Sometimes outdated drivers, check for new drivers for Video card. As said not one complete answer for this kind of issue as many things can cause this. Step by step process. Also be hardware or drivers, as said in link i showed you, HDMI Audio in sound may need to be disabled. Also other drivers on system, go to manufacturer's website for updates to your model. Even PSU can do this.
    I already stated that all my drivers are updated....
    I said that I tried Step 1 and 4, and I've also tried those other steps with no results.
    N.Y.
    Try disconnecting any WiFi if you have it, to rule out this as a cause. Any other speakers you can try ?
    Southern California
    Windows 8.1 Pro with Media Center x64
    Hey mate, I went to the website for your drivers, and many of them are listed for XP - Windows 7, with only a couple being for Windows 8. Chances are, this computer was NOT intended for 8, and you may face stability issues. This would imply that it is a problem with your computer, and not Windows 8 in itself.
    I understand you updated your drivers. However, try uninstalling the audio driver and then reinstalling, provided you haven't previously uninstalled the old driver first before installing the newest one. This driver is listed as being 8.1 friendly, so it should work just fine. If you're careful, you could also try the BIOS update.
    There may be other gimmicks and tricks you could try, but it may not work, as your computer was not built for 8. Good luck though!
    N.Y.
    Yes looking at your model also, had same conclusions as DustSailor. Realtek i find here different from your motherboard site
    Realtek
    Also having difficult time finding update to Integrated AMD Graphics card not specifying 4250 model you have for the newest driver shown.
    Motherboard site has none either, believing may needed to update this. Yes, saw BIOS update but was precautions at motherboard site to update it unless having more issues, be careful there.
    N.Y.
Page 1 of 2 12 LastLast
Latest Realtek High Definition Audio Codecs :ar: Microsoft Update Catalog Realtek download page 6637 Last Updated: June 27th 2017 DRIVER VERSION: 6.0.1.8199 (32-bit and 64-bit Windows Vista, 7, and 8)
Recently I decided to go ahead and update to the Windows 8.1 version of the Realtek HD Audio Driver. I procrastinated because it told me I'd have to uninstall the original audio driver and I knew it would take a while to do everything needed. It didn't help that after uninstalling the original...
I bought a Gateway E56R41u to replace my Acer netbook. I'm really happy with this machine. However, I downloaded the free upgrade to Windows 8.1 and my audio quit working. I've downloaded all the drivers that I could find and nothing works. Is there a driver for another machine that will work...
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
