Realtek audio manager missing
    windows 8.1
    I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for any help
    Quote Originally Posted by derekwyoung View Post
    Re-install the driver vR2.75:
    (click on 'I accept' and 'Next')
    Realtek
    When I install the new driver, everything seems to go well, until I check the date of my driver in device manager, and it still shows the driver from August 2013.
    I see this as the driver version: 6.3.9600.16384
    The new driver first uninstalls the existing driver and then has you reboot the PC, and then installs the new driver.
    Check the Device Manager first before you try installing the new R2.75 version again. In the sound section you should only have RealTek HD Audio and an AMD Radeon HDMI Audio (for HDMI audio) and nothing else. IF you have more than these two, uninstall those in the device manager first and then run the RealTek installer (which as noted uninstalls the existing first).
I have Z87 G43 Gaming Motherboard, it is strange that the Realtek Audio manager no longer starts automatically on startup. I see there is no startup icon in that folder. I uninstalled and reinstalled the Realtek software, but still it does not start automatically. Not sure what could be the issue....
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Hi I need help, can't find a solution and this is slowly driving me crazy... I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates...
Hello Dear Friends, I have Asus All In One ET2701INKI, the problem is the microphone does not work properly, It has dense distortion and echo, microphone works in other devices very well, I read many topics in many forums and I tried so many things but there is no solution, I am using...
I'm using a windows 8 pavilion g7 laptop. Long story short, I wanted to have realtek HD audio on my computer mainly for the cool audio effects that come with it because the audio drivers that came with my computer don't have those effects. Nonetheless, I installed realtek HD audio hoping it would...
So i am going to Reset my PC cause of different issues, and i want to export my Presets i made in Realtek HD Audio Manager, the one you make in the Equalizer and then save. I want to know, where are these save, so i can take them over to a USB drive and after the PC is reseted, i only put them back...
Hey guys, My audio disappeared and stopped working. my audio icon has a red x on it and when i click it it wants to detect problems (it doesn't work). what should i do? how should I diagnose the audio? I feel like this is hardware problem as it just happened out of the blue. The audio...
