Mic volume too low
    Mic volume too low
    Hey is there any way to increase the mic volume besides the one in the controll panal thing? I maxed everything out but it's still not enough ;(...
    What type of mic are you using? Are you using a "computer" mic?
    Also, Please fill in the My System Specs. It helps us to try and help you.
    no i bought a headset like 50 bucks
    how is my specs related to mic? anyways its windows 8.1 , 64 bit .
    Your "System Specs" are the PC brand and model, along with what type of sound card, etc.
    But, I can't really say whether your headset and mic are working properly.
Mic volume too low
I Want Use Windows Mute Volume Icon for nircmd Command. Can I do That ? My New Multimedia Keyboard No Mute Volume Button :( http://i57.tinypic.com/35ndaa9.png Recommend for Icon ?
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Solved Volume keys in Customization
I have a toshiba satellite C855 with windows 8. I used to be able to use my function keys without using fu, but now I have to. Please help me change it back to the way it was.
Solved Volume OSD in Sound & Audio
Solved it on my own! I just ended the Task Manager task, everything seems fine, nothing has died yet :sarc:. So I've been running Windows 8 for a while now, upgraded from Windows 7. Now that Microsoft has implemented a pretty good looking volume OSD I would like to disable the default one....
Volume Bar Placement in Customization
Hi there, Iam using Windows 8 x64 in Desktop Mode. Does anyone know if the placement of the volume bar can be changed? I made a screenshot: http://i47.tinypic.com/2eqb94z.jpg the default position is now in win8 in the left upper area. i want it where it always has been, in the right lower...
Solved Win 8 on volume 2,4? in Installation & Setup
Yep guys I've installed win8 on my HDD, after that everytime I boot to win I got this screen: 11368 After 5sec it will be boot to win 8 on volume 2. I have no idea why I have too much win 8 on diffrent volume. Can someone help me fix it?
