Using an External Sound Card to increase game performance.
    Hello everybody it's been a longtime. I recently found out a game of mine may have some stuttering problems due to it's audio being played without a discrete and/or external sound card of any type. So on your advice, i'd like to know if an external USB sound card can help with some of my performance issues for the game i'm playing.
    Would a external sound card serve as well as a discrete sound for audio playback, or at-least perform better than a on-board sound card?
    Respond as soon as you can, thank you.
    -Arcturus Fyr
    Before you go out and spend $$ on a sound card (and if you opt for an external sound card, don't go cheap or it may not help).
    And, install the Windows 8.1 RealTek driver and see how it acts. www.realtek.com
    Download and run the Resplendence Latency Monitor program and see what that shows you. May be some PC system issue and not the RealTek sound. Resplendence Software - Advanced System Tools and Developer Components
    Thank you for the quick response, i'm unfamiliar with monitoring latency data. Is there anything I should be looking out for specifically? As for an external sound card, is there anything you can recommend at a retail outlet?
    Awaiting your response.
    Arcturus Fyr
    EDIT: As for the Realtek software, would the software updates from my laptop manufacturer website suffice?
    So, this is a Laptop and now the desktop you have in your System Specs? That changes everything.
    I don't understand? My system specs "Computer Type" category has always been "Laptop".
    I missed the Computer type. The rest of the specs looked like a desktop.
    With a Laptop, your limited to USB connected sound "cards". I don't have enough knowledge to suggest one of those.
    Stuttering problems are usually just too much going on at the same time. Sound is always on a shared Interrupt with a higher priority device. If that higher priority device needs to "interrupt" and do something, sound can get momentarily interrupted and sound like stuttering.
    Wi-Fi is also known to be a source of audio problems.
    It's difficult to imagine such configuration would slow down and stutter just because of sound, it's more likely it's a symptom than a cause.
    The sound is fine, it's when the battle music starts and/or ends the game actually micro-stutters. Same with with NPC's talking, put 4 or 5 in same space when they talk and my frame-rate starts dipping like crazy and then come the stuttering too.
    I'm inclined to agree, I guess I was just beating around the bush when I said "game" instead referring the game I was playing specifically.
    The game is the Elder Scrolls IV Oblivion, and the performance issues I have been experiencing have gotten so bad that my older laptop with the weaker specs is seemingly playing the game better than my newer laptop.
    I was hoping an alleviate my issues somewhat with the game by using an external sound card in place of a dedicated sound card as the game has issues with an on-board sound card.
    Here's a quote from Oblivion:Tweaking - UESPWiki in-regards to sound related issues with the game.
    Audio"Try disabling audio and see whether it helps. This is especially true when your game stutters in combat or when many sound sources are around. Onboard sound chips (sound cards built into the motherboard) use the CPU for sound processing, even decent CPU's may experience a severe drop in performance if game sound is processed through the CPU. Purchasing a sound card that performs sound processing with its own independent processor will alleviate this issue. A good example of a sound card with these capabilities is the Creative Audigy or X-Fi series. An excellent sound card can be purchased for between $50 to $100, so it is a worthwhile purchase for users using onboard sound.
    Stuttering related to audio issues can also be caused by buggy sound card drivers. Try updating your sound card/motherboard chipset drivers to their latest version if they aren't already."
    "Disable sound by changing the Oblivion.ini option (in Documents and Files/MyGames/Oblivion):"
Page 1 of 2 12 LastLast
So i was playing halo 2 pc when i got a voice message. Since i always use my trusty mic headset i click play on the message and it said no playback device detected and i tried fixing it with ingame options but it didn't work! and my browser doesn't either. i tried to record my voice but mic wasnt...
Solved Ram performance after size increase in Performance & Maintenance
Hi, I was wondering how RAM is utilized by the system. I recently upgraded my DDR3 4GB Crucial Tactical Tracer 1866Mhz to 8GB. When Running Battlefield 4 (64bit) I kept the performance tab open in task manager and noticed that the Ram usage went up to about 3.2GB of the 8GB total, and...
So here is the explanation. My computer both back and front part the analogs. The pink green and blue is not working. So I don't have anymore audio. But somebody told me about connecting a USB in my headphone. Now I buyed one. And I have USB as my audio. Now my problem is. I play games some have in...
all, Here's what I generally have open at the same time on any development machine (windows) that I use: 10 firefox tabs Excel (2 instances) Access (2 instances) Skype A screen sharing program (like GoToMeeting / join.me) 1 youtube video
I'm in the market to buy a headset for chat in online gaming, at the moment game sound is through my gtx cards hdmi to my tv speakers and I want the headset for purely just voice (like Xbox). In layman's terms how would I set it up this way? A friend said he thought the game sounds as well as...
Card game Hearts in Gaming
How can I download the card game HEARTS. My old Vista had this option but cannot find it here. Thanks.
Hi all Just installed win 8 the other day, everything ran smooth and system using allmost no Memory only 1.7 to 3gigs used. then i figured id try some of my games, started out with no problems.. 1 hour of world of tanks and then i switched over to BF3 after around 2hours it started to lag out...
