Solved Using an External Sound Card to increase game performance.
Arcturus Fyr
Hello everybody it's been a longtime. I recently found out a game of mine may have some stuttering problems due to it's audio being played without a discrete and/or external sound card of any type. So on your advice, i'd like to know if an external USB sound card can help with some of my performance issues for the game i'm playing.
Would a external sound card serve as well as a discrete sound for audio playback, or at-least perform better than a on-board sound card?
Respond as soon as you can, thank you.
-Arcturus Fyr
    Sager NP9377 (Clevo P377 SM-A)
    Intel i7 4810MQ
    MXM Sager
    Dual-Channel 16gb 1600mhz 2x8 (Stock)
    Nvidia GeForce GTX 980m SLI gddr5 w/8gb Vram dedicated
    Sound Blaster XFi-3
    17'inch Single-Monitor Display
    1920x1080p
    (Stock) x3 1 Terabyte 7200rpm SATA III
    330 Watts
    Stock Matte Finish Chassis
    Twin Fans and Copper Cooling System w/ Targus Chill Hub cooling pad
    Logitech
    300-360kb
    Malwarebytes Anti-Malware - Free Edition w/ Eset Nod 32 v.4
    Still playing Oblivion, are you?
Before you go out and spend $$ on a sound card (and if you opt for an external sound card, don't go cheap or it may not help).
And, install the Windows 8.1 RealTek driver and see how it acts. www.realtek.com
Download and run the Resplendence Latency Monitor program and see what that shows you. May be some PC system issue and not the RealTek sound. Resplendence Software - Advanced System Tools and Developer Components
Thank you for the quick response, i'm unfamiliar with monitoring latency data. Is there anything I should be looking out for specifically? As for an external sound card, is there anything you can recommend at a retail outlet?
Awaiting your response.
Arcturus Fyr
EDIT: As for the Realtek software, would the software updates from my laptop manufacturer website suffice?
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
So, this is a Laptop and now the desktop you have in your System Specs? That changes everything.
I don't understand? My system specs "Computer Type" category has always been "Laptop".
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
I missed the Computer type. The rest of the specs looked like a desktop.
With a Laptop, your limited to USB connected sound "cards". I don't have enough knowledge to suggest one of those.
Stuttering problems are usually just too much going on at the same time. Sound is always on a shared Interrupt with a higher priority device. If that higher priority device needs to "interrupt" and do something, sound can get momentarily interrupted and sound like stuttering.
Wi-Fi is also known to be a source of audio problems.
It's difficult to imagine such configuration would slow down and stutter just because of sound, it's more likely it's a symptom than a cause.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
The sound is fine, it's when the battle music starts and/or ends the game actually micro-stutters. Same with with NPC's talking, put 4 or 5 in same space when they talk and my frame-rate starts dipping like crazy and then come the stuttering too.
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
I'm inclined to agree, I guess I was just beating around the bush when I said "game" instead referring the game I was playing specifically.
The game is the Elder Scrolls IV Oblivion, and the performance issues I have been experiencing have gotten so bad that my older laptop with the weaker specs is seemingly playing the game better than my newer laptop.
I was hoping an alleviate my issues somewhat with the game by using an external sound card in place of a dedicated sound card as the game has issues with an on-board sound card.
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
Here's a quote from Oblivion:Tweaking - UESPWiki in-regards to sound related issues with the game.
Audio"Try disabling audio and see whether it helps. This is especially true when your game stutters in combat or when many sound sources are around. Onboard sound chips (sound cards built into the motherboard) use the CPU for sound processing, even decent CPU's may experience a severe drop in performance if game sound is processed through the CPU. Purchasing a sound card that performs sound processing with its own independent processor will alleviate this issue. A good example of a sound card with these capabilities is the Creative Audigy or X-Fi series. An excellent sound card can be purchased for between $50 to $100, so it is a worthwhile purchase for users using onboard sound.
Stuttering related to audio issues can also be caused by buggy sound card drivers. Try updating your sound card/motherboard chipset drivers to their latest version if they aren't already."
"Disable sound by changing the Oblivion.ini option (in Documents and Files/MyGames/Oblivion):"
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
USB sound chips are even more CPU dependent, they can't do anything on their own. Maybe you can try cutting down on sound quality. CP > Sound > Speakers > properties > Advanced.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I tried doing that in the past, lowering the settings from the default 48000hz (Studio Quality 24-bit) to 44100hz (Studio Quality 24-bit) setting. Anything lower and i'd be compromising overall sound quality, still, I suppose I can try something lower. I'll try to keep this thread updated on my progress.
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
Well, I decided to change my audio quality to 16-bit 48000 (DVD Quality) and the game run perfectly, I even maxed out some settings I couldn't before and my game still runs fine.
Thank you CountMike for the great advice!
P.S I don't suppose there's another way of increasing sound quality whilst keeping this performance is there?
EDIT: I'll keep this thread unsolved for another day for any additional feedback (if the moderators will allow it. Thanks!)
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
Some games have their own settings for sound quality, don't know abut that one. Thread will not be closed even if you mark it solved, just may attract less attention.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Alright, thanks again for the help. The new setting seems to have helped a lot with another game; "Fallout New Vegas". This tweak may have saved me a tremendous amount of time and money.
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
No problem, I don't know about state of your hearing but for the life of me I could not hear difference between 16 and 48 bit sound even with good sound system.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
The only difference I notice is that the in-game sound is severely lowered, not quality, just volume. Fixable with either the in-game settings, or desktop volume control.
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
Sound quality is also limited with original sound generated. If the sound is recorded in 16 bit for instance, turning reproduction to anything higher is not doing to help, output sound will still be 16bit.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I would set it to 16 bit 44.1Khz (CD Quality). That is what commercial audio CD's are. I have a recording studio and the 48Khz is only used for audio when it is intended to be used with a (commercial) video.
