Using an External Sound Card to increase game performance.
  1. #11
    USB sound chips are even more CPU dependent, they can't do anything on their own. Maybe you can try cutting down on sound quality. CP > Sound > Speakers > properties > Advanced.
  2. #12
    I tried doing that in the past, lowering the settings from the default 48000hz (Studio Quality 24-bit) to 44100hz (Studio Quality 24-bit) setting. Anything lower and i'd be compromising overall sound quality, still, I suppose I can try something lower. I'll try to keep this thread updated on my progress.
  3. #13
    Well, I decided to change my audio quality to 16-bit 48000 (DVD Quality) and the game run perfectly, I even maxed out some settings I couldn't before and my game still runs fine.
    Thank you CountMike for the great advice!
    P.S I don't suppose there's another way of increasing sound quality whilst keeping this performance is there?
    EDIT: I'll keep this thread unsolved for another day for any additional feedback (if the moderators will allow it. Thanks!)
  4. #14
    Some games have their own settings for sound quality, don't know abut that one. Thread will not be closed even if you mark it solved, just may attract less attention.
  5. #15
    Alright, thanks again for the help. The new setting seems to have helped a lot with another game; "Fallout New Vegas". This tweak may have saved me a tremendous amount of time and money.
  6. #16
    Quote Originally Posted by Arcturus Fyr View Post
    No problem, I don't know about state of your hearing but for the life of me I could not hear difference between 16 and 48 bit sound even with good sound system.
  7. #17
    The only difference I notice is that the in-game sound is severely lowered, not quality, just volume. Fixable with either the in-game settings, or desktop volume control.
  8. #18
    Sound quality is also limited with original sound generated. If the sound is recorded in 16 bit for instance, turning reproduction to anything higher is not doing to help, output sound will still be 16bit.
  9. #19
    I would set it to 16 bit 44.1Khz (CD Quality). That is what commercial audio CD's are. I have a recording studio and the 48Khz is only used for audio when it is intended to be used with a (commercial) video.
Page 2 of 2 FirstFirst 12
So i was playing halo 2 pc when i got a voice message. Since i always use my trusty mic headset i click play on the message and it said no playback device detected and i tried fixing it with ingame options but it didn't work! and my browser doesn't either. i tried to record my voice but mic wasnt...
Solved Ram performance after size increase in Performance & Maintenance
Hi, I was wondering how RAM is utilized by the system. I recently upgraded my DDR3 4GB Crucial Tactical Tracer 1866Mhz to 8GB. When Running Battlefield 4 (64bit) I kept the performance tab open in task manager and noticed that the Ram usage went up to about 3.2GB of the 8GB total, and...
So here is the explanation. My computer both back and front part the analogs. The pink green and blue is not working. So I don't have anymore audio. But somebody told me about connecting a USB in my headphone. Now I buyed one. And I have USB as my audio. Now my problem is. I play games some have in...
all, Here's what I generally have open at the same time on any development machine (windows) that I use: 10 firefox tabs Excel (2 instances) Access (2 instances) Skype A screen sharing program (like GoToMeeting / join.me) 1 youtube video
I'm in the market to buy a headset for chat in online gaming, at the moment game sound is through my gtx cards hdmi to my tv speakers and I want the headset for purely just voice (like Xbox). In layman's terms how would I set it up this way? A friend said he thought the game sounds as well as...
Card game Hearts in Gaming
How can I download the card game HEARTS. My old Vista had this option but cannot find it here. Thanks.
Hi all Just installed win 8 the other day, everything ran smooth and system using allmost no Memory only 1.7 to 3gigs used. then i figured id try some of my games, started out with no problems.. 1 hour of world of tanks and then i switched over to BF3 after around 2hours it started to lag out...
