why no sound at the start or when i reboot/shutdown ?
    Winodws 8.1 Pro 64
    Hi
    i have w8.1 pro 64bit with all the update
    i noticed that at the start or reboot/shut down there are not sounds
    is it normal ?
    i checked controll panel ->audio ->there is default windows sounds
    thanks
    There is an option in the Panel that has the system sounds. At the bottom is a box to check to have startup sounds.
    See screenshot from my Win 8.1 system
    Winodws 8.1 Pro 64
    thanks a lot
    but can i select the sound ?
    and there is only the option for the startup or is there an option to add a sound when i log off/shut down ?
    It can be turned on but there's no way (that I know of) to assign sound to it. Option to assign it is greyed out. It's fixed in W10TP.
    Winodws 8.1 Pro 64
    hi
    thanks and about the shutdown/log off ?
    is there a way to have a sound?
    they could fix with an update!
    Quote Originally Posted by drugo View Post
    hi
    If it's not on the list of already installed sounds, I could not see a way to do it.
    Newport, South Wales, UK
    Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
    No guarantee that this is still current but it may work
    Make sure you fully back-up the registry before you start, just in case
    How to Enable Options to Customize Windows Logon, Logoff, Exit and Unlock Sounds in Windows 8? - AskVG
    Quote Originally Posted by Barman58 View Post
    Thanks but I don't think it's worth the risk.
    Unfortunately, that will add the sound events back into "Sounds" and let you set them, but they do not actually work or play.
    Thought it looked too simple
Page 1 of 2 12 LastLast
I do a shutdown from the Windows Logon screen which I believe is a full power off rather than a hybrid shutdown: (The process C:\WINDOWS\system32\winlogon.exe (XXXXX) has initiated the power off of computer XXXX on behalf of user NT AUTHORITY\SYSTEM for the following reason: No title for this...
I swapped my motherboard/CPU, and mostly got away without having to reinstall windows, save this BSOD that occurs whenever I shutdown or restart my computer. The computer hangs up on the "Shutting Down" or "Restarting" screen for a significant period of time before producing this BSOD. It seems to...
I've got Toshiba Encore with Win 8.1. I notice few times an issue after restart or shut down - black screen. Tablet was still running (Windows key vibrates). Only holding power button helps. What I checked with no success: - turning off fast boot - turing off hdd encryption - restore...
In order to run Corel Draw X6 I need a service to run in the background, called PSI-SVC-2, also known as Protexis Licencing V2. Under Task Manager/Services it's always default set to "Stopped". No matter how many times I set it to start automatically, it always resets to Manual after a restart....
My laptop was frozen and I couldn't get to my start menu to restart it so I did a hard reboot. Now when I try to start the blue windows icon comes up for a few seconds with the rotating dots then the screen goes black. Eventually I hear the windows start up sound, but nothing on the screen.
Just did a fresh install of Win 8 Pro on my Intel 520 180GB SSD. I installed the OS on the SSD first, once that was done I added in my 1TB HDD. I also disabled the hibernation thru command prompt and I'm guessing maybe this is why I'm having issue in Win 8. I can reinstall the OS again however my...
