JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
why no sound at the start or when i reboot/shutdown ?
Hi
i have w8.1 pro 64bit with all the update
i noticed that at the start or reboot/shut down there are not sounds
is it normal ?
i checked controll panel ->audio ->there is default windows sounds
thanks
Beach Observer
There is an option in the Panel that has the system sounds. At the bottom is a box to check to have startup sounds.
See screenshot from my Win 8.1 system
OS
thanks a lot
but can i select the sound ?
and there is only the option for the startup or is there an option to add a sound when i log off/shut down ?
It can be turned on but there's no way (that I know of) to assign sound to it. Option to assign it is greyed out. It's fixed in W10TP.
OS
Home made
AMD Ryzen7 2700x
Asus Prime x470 Pro
16GB Kingston 3600
Asus strix 570 OC 4gb
Samsung 960 evo 250GB
Silicon Power V70 240GB SSD
WD 1 TB Blue
WD 2 TB Blue
Bunch of backup HDDs.
Sharkoon, Silent Storm 660W
Raidmax
CCM Nepton 140xl
40/2 Mbps
WD
hi
thanks and about the shutdown/log off ?
is there a way to have a sound?
they could fix with an update!
hi
If it's not on the list of already installed sounds, I could not see a way to do it.
OS
Home made
AMD Ryzen7 2700x
Asus Prime x470 Pro
16GB Kingston 3600
WD 1 TB Blue
WD 2 TB Blue
Raidmax
CCM Nepton 140xl
40/2 Mbps
WD
Super Moderator
Super Moderators
OS
Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
Real World Computing
AMD FX8350 8 Core @4GHz
Asus M5A78L-M USB3
32GB [4x8GB] DDR3 1600 MHz
Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
ASUS Xoner DG + SPDIF to 5.1 System + HDMI
Acer G276HL 27", (DVi) + Samsung 39" HDTV (HDMI)
1920 x 1080 @60Hz + 1920 x 1080 @60Hz
Internal
Crucial 256GB SSD,
WDC WD30EZRX-00D8PB0 3TB,
Toshiba HDWD130 3TB
Seagate ST2000DM001-1CH1 2TB,
External (USB3)
Seagate Backup+ Hub BK SCSI Disk 8TB
2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
NAS
Seagate ST4000DM000
Aerocool Templarius Imperator 750W 80+ Silver
AeroCool X-Warrior Devil Red Tower
Stock CPU, Rear 120mm, Front 2x120mm, Side 2x120mm
Logitech Wireless K710 & K270
Logitech Wireless M710 M185 & M570 Trackball
37Mb/s Down - 9.5Mb/s Up
Chrome
BitDefender Total Security 2017
Also run...
Desktop - 6Core 8GB - Windows 10 Enterprise x64,
Laptop - Quad 8GB - Windows 10 Pro x64
Netbook - Ubuntu
2 x Nexus 7 Android tablets
Samsung 10.2" tablet
Sony Z3 Android Smartphone
HTC One Android Smartphone
OS
Home made
AMD Ryzen7 2700x
Asus Prime x470 Pro
16GB Kingston 3600
WD 1 TB Blue
WD 2 TB Blue
Raidmax
CCM Nepton 140xl
40/2 Mbps
WD
OS
Super Moderator
Super Moderators
Thought it looked too simple
OS
Asus M5A78L-M USB3
Internal
Crucial 256GB SSD,
Toshiba HDWD130 3TB
External (USB3)
NAS
Seagate ST4000DM000
Chrome
Also run...
Netbook - Ubuntu
My start up sound comes and goes. Sometimes it works, sometimes not. I've just accepted it.
OS
Windows 8.1 Pro 64-bit
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
8GB DDR3 PC3-12800 (800 MHz)
HD4000 + GeForce GT 730M
Realtek High Definition Audio
1600x900 pixels
Samsung SSD 850 EVO 250 GB
ADATA SSD SP900 128GB
90 watt brick
Bluetooth
Comodo
Please don't ask why and how but I got startup sound and it's from Win7. Still can't choose which sound but it's there. If I was to guess it would be because this 8.1.1 and Win10TP i have in dual boot are syncing all the time and sound is enabled and running there.
OS
Home made
AMD Ryzen7 2700x
Asus Prime x470 Pro
16GB Kingston 3600
WD 1 TB Blue
WD 2 TB Blue
Raidmax
CCM Nepton 140xl
40/2 Mbps
WD
